Hi folks,
I have a head pain due to something that i try to solve. Let me explain the case.
I have my arduino sleeping. It gets up thanks to the alarm from a RTC. Then, it measure by different sensors, save the data into a SD card, and come back to sleep again. It works perfect.
Now, I also want to control my devide sending commands by the serial port (in fact by a bluetooth). So, i connected the Rx pin to the Int0 (the same where is connected the alarm, because i use the other one to do other things.
The problem is that i am doing something wrong because in all cases i send a command, it made the default task, like if didn´t read anything by the serial port, and just only receiving the interrupt... I changed the position of the routine what reads the serial port and decide what task to develop... but i didn´t see where is the problem.
Did you see where is the problem? or what i am doing wrong?
[code]
// Here goes all the call to libraries, constant and variables. I removed in order to save space in this forum
void setup(){
// Inicializacion RTC
RTC.start();
// Configuración de la alarma
RTC.enable_interrupt();
RTC.setSeconds(55);
RTC.setMinutes(59);
RTC.setAlarmRepeat(EVERY_HOUR);
RTC.writeAlarm();
pinMode(alarma, INPUT); // Receptor de alarmas
digitalWrite(alarma, HIGH);
// Configuración de pins
pinMode(power, OUTPUT); // Alimentacion de sensores
// Inicializacion del puerto serie
Serial.begin(115200); // Inicia comunicaciones
// Comprobación de la tarjeta SD
pinMode(10, OUTPUT); // Configuración de la librería SD
if (!SD.begin(chipSelect)) {
Serial.println("WProblemas con la tarjeta de memoria SD");
else {
Serial.println("WTarjeta de memoria SD preparada");
void loop(){
// Fin de la medición, Inicio del letargo
Dormir();
// Función tras despertar
void Despertar(){
c = Serial.read() ;
// Realizar las mediciones de los sensores
void Mediciones(){
// Inicialización de sensores
sensors.begin(); // Inicia el sensor de temperatura DS18B20
sensors2.begin();
// Alimentación de sensores
digitalWrite(power, HIGH);
delay(5000);
// Inicio de la medición de parámetros ambientales
tiempo(); // Toma la hora
delay(20);
readVcc(); // Lee el voltaje interior
delay(20);
midebateria(); // Mide el voltaje de entrada
delay(20);
readTemp(); // Mide la temperatura interna
delay(20);
midegotas(); // Mide la intensidad de lluvia (disdrómetro)
delay(20);
temperatura(); // Mide la temperatura exterior (DS18B20)
delay(20);
sueloH(); // Mide la humedad del suelo
delay(20);
suelotemp(); // Mide la temperatura del suelo
delay (20);
temphumroc(); // Lee temperatura y humedad (SH15) y calcula el punto de rocío
delay (20);
luminosidad(); // Mide la luminosidad (LDR)
delay (20);
radiacion(); // Mide la radiación luminosa, irradiancia (TSL235R)
delay(20);
velocidadviento(); // Mide la velocidad del viento (QRD1114)
// Grabación de los resultados
grabar(); // Graba los datos en formato ascii en un soporte microSD
delay(5000);
contador = contador + 1; // Actualiza el contador de medidas
digitalWrite(power, LOW);
// Configuración del estado de letargo
void Dormir(){
attachInterrupt(0, Despertar, FALLING);
set_sleep_mode(SLEEP_MODE_PWR_DOWN);
sleep_enable();
sleep_mode();
// -->FASE DE LETARGO DEL DISPOSITIVO<--
sleep_disable();
RTC.disable_interrupt();
detachInterrupt(0);
Leermensaje();
// Procesar mensaje del puerto serie
void Leermensaje() {
if(Serial.available() >= 0 ){
//char c = Serial.read() ;
if ( c == 'T' ) {
setuptime();
else if ( c == 'D'){
DescargaDatos();;
else {
Mediciones();
// Actualizar la hora del RTC a través del puerto serie
void setuptime(){
int pctime = 0;
for(int i=0; i < TIME_MSG_LEN -1; i++){
char c = Serial.read();
if( c >= '0' && c <= '9'){
pctime = (10 * pctime) + (c - '0') ; // convert digits to a number
RTC.writeTime(pctime); // Sync clock to the time received on serial port
Serial.print('T');
Serial.print(pctime);
// Volcado de datos en el puerto serie
void DescargaDatos(){
Serial.println("WTarjeta SD inicializada");
File dataFile = SD.open("datos.csv");
//Serial.println(dataFile.size());
if (dataFile) {
Serial.println("WIniciando la descarga de datos");
while (dataFile.position() < dataFile.size()) {
Serial.write(dataFile.read());
dataFile.close();
Serial.println("@");
Serial.println("WDescarga completa");
else {
Serial.println("WError al abrir datos.csv");
// Lee el Reloj de Tiempo Real (DS1337)
void tiempo(){
// Lee el RTC
RTC.readTime();
// Memoriza la fecha actual
day = RTC.getDays();
month = RTC.getMonths();
year = RTC.getYears();
//Memoriza la hora actual
hora = RTC.getHours();
minuto = RTC.getMinutes();
segundo = RTC.getSeconds();
return;
// Lee el voltaje de entrada
float midebateria(){
batt = (analogRead(bateria))*volt;
return batt;
//Lee el voltaje interno
long readVcc() {
long readVcc=0;
ADMUX = _BV(REFS0) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
delay(2);
ADCSRA |= _BV(ADSC);
while (bit_is_set(ADCSRA,ADSC));
readVcc = ADCL;
readVcc |= ADCH<<8;
innerVcc = 1126400L / readVcc; // Back-calculate AVcc in mV
innerVcc = innerVcc / 1000;
return innerVcc;
// Obtiene la temperatura interna de dispositivo Arduino
long readTemp() {
long readTemp=0;
ADMUX = _BV(REFS1) | _BV(REFS0) | _BV(MUX3);
delay(20);
readTemp = ADCL;
readTemp |= ADCH<<8;
innertemp = (readTemp - 125) * 1075; // temp in x10^-4 degC
innertemp = innertemp / 10000; // temp in degC
return innertemp;
// Mide la temperatura y humedad ambiental y calcula el punto de rocío
void temphumroc(){
SH15.measure(&ambtemp, &humedad, &TRocio);
// Lee la irradiancia (TSL235R)
void radiacion(){
volatile long pulsos = 0;
for (int i=0; i <= 10; i++){
FreqCounter::f_comp = 10;
FreqCounter::start(periodo1);
while (FreqCounter::f_ready == 0)
pulsos=FreqCounter::f_freq;
delay(20);
irrad = (pulsos*1000)/(periodo1*area1*1000);
return;
// Lee la temperatura superficial (DS18B20)
float temperatura() {
sensors.requestTemperatures();
tempext=sensors.getTempCByIndex(0);
return tempext;
int sueloH(){
suelohum=analogRead(suelo); // Read the sensor
suelohum=(suelohum*0.1904761905); // Calculate soil moisture from the lecture*100/525
return suelohum;
// Mide la temperatura del suelo (DS18B20)
void suelotemp() {
sensors2.requestTemperatures();
TSAr=sensors2.getTempCByIndex(0);
TSAb=sensors2.getTempCByIndex(1);
return;
unsigned int luminosidad(){
float photocellReading0 = analogRead(luz); // Read the analogue pin
float Vout0=photocellReading0*0.0048828125; // calculate the voltage
lux=500/(10*((5-Vout0)/Vout0)); // calculate the Lux
return lux;
unsigned long midegotas() {
volatile unsigned long gotas=0;
unsigned long millis();
long startTime = millis(); // mide el numero de gotas en 30 segundos
while(millis() < startTime + 30000) {
int sensorReading = analogRead(lluvia);
if (sensorReading >= sensibilidad) {
gotas=gotas+1;
intensidad = ((gotas / area2) / 30); // calcula la intensidad de la lluvia en gotas/m2/sec
void velocidadviento(){
BWCounter = 0;
attachInterrupt(1, addcount, CHANGE);
while(millis() < startTime + periodo2) {
detachInterrupt(1);
unsigned int RPM=((BWCounter/2)*60)/(periodo2/1000); // Calculate revolutions per minute (RPM)
velviento = ((pi * diametro * RPM)/60) / 1000; // Calculate wind speed on m/s
// Contaje de pulsos anemómetro
void addcount(){
BWCounter++;
// Graba los datos en formato ASCII en una memoria flash SD
void grabar(){
// It works... i removed to save space in the forum
// Muestra los datos en el puerto serie
Serial.print(message);
return;
Excuse to paste here all the code, but in this way you have all the information and not only the partial one...
Thanks![/code]
