Question about SPI control TOSHIBA TC9459F IC?
Hello Guys
I am learning how to control TOHIBA TC9459F IC chip, which is a electronic volume control IC.
This chip using SPI to control
this is my testing code in Arduino
#include <SPI.h>
#define CSPin 2
byte L = B11100100;
byte R = B00011001;
byte LD = B00001101;
//byte CS = B0001;
uint16_t temp = 0;
  pinMode(CSPin, OUTPUT);
  digitalWrite(CSPin,HIGH);
  digitalWrite(SS,HIGH);
  // initialize SPI:
  SPI.begin();
  SPI.beginTransaction(SPISettings(1000000, LSBFIRST, SPI_MODE0));
  //for debug and demostration
  //for(int i=0;i<=89;i++)
    TC9459F_Write(L, R, LD);
  //  TC9459F_Write(89-i, R, LD);
void TC9459F_Write(uint8_t LeftVolume, uint8_t RightVolume, const bool Loundness)
  // take the CS pin low to select the chip:
  digitalWrite(SS, LOW);
  //delay(100);
  //  send in the value via SPI:
  SPI.transfer(LeftVolume);
  SPI.transfer(RightVolume);
  SPI.transfer(Loundness);
  //SPI.transfer(CS);
  //delay(100);
  // take the CS pin high to de-select the chip:
  digitalWrite(SS, HIGH);
I am try to send LeftVolume, RightVolume and LD binary data to TC9459
byte L = B11100100;
byte R = B00011001;
and I used Loghic 2 to show the result.
The LeftVolume and RightVolume data are correct, but the LD data is not. what is wrong with it ?
No matter what I sent to LD, it is still b1000 0000
5
Only I sent b00000000, it will b0000 0000
6
could it be
because Loundness is declared as a bool??
Oh yes, thank you very much.
I works now. Thank you very much.
3
东芝TC9459F-音量控制芯片.pdf (416.1 KB)
This is the datasheet of the TC9459F IC chips, it is a digital volume control IC
But I can't control it with Arduino UNO.
This is my testing code:
#include <SPI.h>
 STB(12)->Arduino(10)
 DATA(11)->Arduino(11)
 SCK(10)->Arduino(13)
#define CSPin_L 2
#define CSPin_R 3
byte L = B01001100;
byte R = B01010000;
byte LD = B10110000;
//byte CS = B0001;
int inputNum = 50;
  pinMode(CSPin_L, OUTPUT);
  pinMode(CSPin_R, OUTPUT);
  digitalWrite(CSPin_L, HIGH);
  digitalWrite(CSPin_R, HIGH);
  // initialize SPI:
  SPI.begin();
  SPI.beginTransaction(SPISettings(500000, LSBFIRST, SPI_MODE0));
  Serial.setTimeout(5);
  // Flush the input buffer
  //while (Serial.available())
  //Serial.read();
  //  inputNum = Serial.parseInt();
  //  Serial.print("input = ");
  //  Serial.println(inputNum);
  TC9459F_Write(inputNum, inputNum, LD);
  //for(int i=0;i<90;i++)
  //  TC9459F_Write(i, i, LD);
  //for(int i=90;i>=0;i--)
  //delay(1000);
void TC9459F_Write(uint8_t LeftVolume, uint8_t RightVolume, uint8_t Loundness)
  digitalWrite(CSPin_L, LOW);
  //delay(100);
  //SPI.transfer(CS);
  //delay(100);
When I set inputNum to 0
this is what I got from CK(pin 13), DATA(pin 11) and STB(pin 10)
There is no attenuation of the signal.
It is correct.
But when I set inputNum to 50
it is -50dB attenuation according to datasheet
but no attenuation of the output.
What is the problem of the code?
