Question about Switches
Hi, beginner Arduino and electronics hobbyist here --- just getting started.
I have purchased these switches with the red buttons, and I'm trying to replicate this circuit from the Button tutorial.
However, the switches in this tutorial have 4 prongs. I know they are technically the same, but how would I wire up the circuit from the tutorial with the new buttons that have 2 prongs.
Thanks for your help,
Charlie
The push button switches generally have pins 1/2 and 3/4 wired together (or 1/3 and 2/4, depending on how numbered). If you only have 2 prongs, that makes it easy - one side will go to the arduino pin, and the other side will go to +5 of Gnd, whatever the schematic calls for.
Thanks CrossRoads
How do I incorporate the resistor and the connections to both the GND and 5V sockets on one-side of the switch without a breadboard? Just solder connections?
Charlie
Sure. I prefer this tho: Connect one side of switch to arduino pin, the other to ground. Enable the internal pullup resistor. Then watch for a low on the pin to show the button is pressed.
Thanks again, I will give this a go!
Pull-up resistors - cool stuff, new to me.
Charlie
Dear Charlie...
We were all there once! It is so hard, once you've "got going" to recall the things that "didn't make sense"....
Anyway... I hope you will find...
http://sheepdogguides.com/arduino/aht0button.htm
... useful. Talks about the basic issues of connecting switches.
By the way... get a breadboard and a (cheap-ish, for now) multimeter!
Breadboard: Lots of sources, e.g....
http://shop.moderndevice.com/products/mini-breadboard
(Get at least two... more if you can. They're small. But 2 small is more flexible than 1 large.)
If your partner doesn't hear that I sent you there, and you are ready for WAY too much temptation, go to Sparkfun.com They have breadboards, too... and a WHOLE lot more!
(I've gone with the odds, and guessed you are in the US. Add at least a country to your profile, if, say, you live in the UK and would rather hear of UK suppliers.)
