Question about the ESP8266 Arduino IDE Wifi scanning
Hello I'm using the Sample Esp8266 wifi scanning sketch to scan for networks. It great and all. But The problem is i only would like to scan one channel only and not all the channels at once. I been searching online for help and only things i found was for scanning all channels. I'm not sure how i can only scan one channel. The example sketch i have below is just for to scan all channels.
    This sketch demonstrates how to scan WiFi networks.
    The API is almost the same as with the WiFi Shield library,
    the most obvious difference being the different file you need to include:
#include "ESP8266WiFi.h"
  // Set WiFi to station mode and disconnect from an AP if it was previously connected
  WiFi.mode(WIFI_STA);
  WiFi.disconnect();
  delay(100);
  Serial.println("Setup done");
  Serial.println("scan start");
  // WiFi.scanNetworks will return the number of networks found
  int n = WiFi.scanNetworks();
  Serial.println("scan done");
  if (n == 0) {
    Serial.println("no networks found");
    Serial.print(n);
    Serial.println(" networks found");
    for (int i = 0; i < n; ++i) {
      // Print SSID and RSSI for each network found
      Serial.print(i + 1);
      Serial.print(": ");
      Serial.print(WiFi.SSID(i));
      Serial.print(" (");
      Serial.print(WiFi.RSSI(i));
      Serial.print(")");
      Serial.println((WiFi.encryptionType(i) == ENC_TYPE_NONE) ? " " : "*");
      delay(10);
  Serial.println("");
  // Wait a bit before scanning again
  delay(5000);
I'm not much of a coder but Wifi still new to me.
Joseph
Looking at the headers for this library on GitHub I see this:
        int8_t scanNetworks(bool async = false, bool show_hidden = false, uint8 channel = 0, uint8* ssid = NULL);
Which implies that you can specify a channel to search for.
Hello Wildbill Thank you. May i knowwhich GitHub are you speaking of?
Joseph
Hello wildbill thank you for the link. I'm checking it out now.
Joseph
