Question about the "Flash" library, PROGMEM and how to do something.
Hi all,
I can send a string to the serial port from PROGMEM very easily by doing this:
	FLASH_STRING(menu,
		"\r\n"
		"  Four Valve Independent Controller - Main Menu\r\n"
		"\r\n"
		"  Please select an option\r\n"
		"\r\n"
		"    (1) Run controller\r\n\r\n"
		"    (2) Configure valve timing\r\n\r\n"
		"    (3) Review all valve timings\r\n\r\n"
		"    (4) Change serial baud rate\r\n\r\n"
		"    (5) Display free memory (debug)\r\n\r\n"
		"    (6) View license information\r\n\r\n"
		"    Option: "
	menu.print(Serial);
But, if I want to place a TEMPLATE to use with "sprintf" in PROGMEM (like this):
    char buffer[32];
    FLASH_STRING(template, "You used %d moves to complete the puzzle\r\n");
    sprintf(buffer, template, moves);
    Serial.write(buffer);
...it doesn't work. The "template" object has no generic member with which to access it (that I know of).
Can anyone show me how to do what I want to do (i.e. use a string in PROGMEM as an SPRINTF template)?
Thanks!
-- Roger
A quick Google search for "AVR sprintf progmem" came up with a reference to sprintf_P() which expect the formatting string to be in PROGMEM. You can even format strings from PROGMEM using the %S format specifier instead of %s.
johnwasser:
Neat! Thanks.
I would have Googled it if I knew what to Google! :slight_smile:
Thanks again!
-- Roger
johnwasser:
OK I've been looking and I still don't get it.
If I do this:
        const char *menu2 PROGMEM =
                "    (3) %s this channel\r\n\r\n"
                "    Option:  ";
is that string in flash memory? If so, then I'm confused as to what the "sprintf_P()" thing is for, since plain old "sprintf" works with "menu2" as a format string.
What I am hoping to do is move all my sprintf formatting strings into flash (PROGMEM) so that as little as possible of SRAM is used.
Can you provide me a little bit more guidance please?
Thanks.
-- Roger
Initially it is because that is the only place for code, but it is copied to RAM because you didn't specify that it should stay in program memory.
Krupski:
If I do this:
                "    Option:  ";
No. The pointer is in FLASH but the string is copied to SRAM. See the reference: http://www.arduino.cc/en/Reference/PROGMEM
Setting up a table (array) of strings in program memory is slightly complicated, but
here is a good template to follow.
Setting up the strings is a two-step process. First define the strings.
#include <avr/pgmspace.h>
prog_char string_0[] PROGMEM = "String 0"; // "String 0" etc are strings to store - change to suit.
prog_char string_1[] PROGMEM = "String 1";
prog_char string_2[] PROGMEM = "String 2";
prog_char string_3[] PROGMEM = "String 3";
prog_char string_4[] PROGMEM = "String 4";
prog_char string_5[] PROGMEM = "String 5";
// Then set up a table to refer to your strings.
PROGMEM const char *string_table[] = // change "string_table" name to suit
string_0,
string_1,
string_2,
string_3,
string_4,
string_5 };
Of course if you don't need a table of your strings you can skip the second part and reference the strings individually.
johnwasser:
OK forgive me for being so dense, but is THIS right (i.e. the string is in PROGMEM and stays there)?
// buffer is defined already FYI
        prog_char menu2[] PROGMEM = {
                "    Option:  "
        sprintf(buffer, menu2, P_enabled[v-1] ? "Disable" : "Enable ");
Is this right?
Krupski:
                "    Option:  "
Is this right?
Close. Remember that if the format string is in PROGMEM you have to use sprintf_P(). Other than that it looks correct to me (depending on the declarations of buffer, P_enabled[], v, etc).
johnwasser:
I know that I'm "supposed" to use sprintf_P() - but the strange thing is that it works WITHOUT it (i.e. using plain old sprintf()).
That's why I asked if I was doing it correctly. I assumed that it should fail if I use plain sprintf().
-- Roger
