The problem is that if I send a number through the Serial monitor the x has that value only for one iteration, it then changes to another. I dont really understand whats happening.
You should probably only print out 'x' when you read a new 'x', not every half second regardless:
if (Serial.available() > 0)
int x = Serial.read();
Serial.println(x);
When I type "123(return)" into Serial Monitor set for "Newline" line endings, I get:
49
50
51
10
49 is the character code for '1'.
50 is the character code for '2'.
51 is the character code for '3'.
10 is the character code for '\n' (ASCII New Line)
When we open a circuit for analog (voice) communications, we carry a modulated signal independent of the language being spoken. Similarly, when a channel is opened for digital communications, a serial bit-stream is processed, independent of the protocol.
