Question about the USB keyboard emulator.
I've built this thingy:http://www.practicalarduino.com/projects/virtual-usb-keyboard
and it works a treat, but I want to send a character with 2 control codes, and that doesn't work.
For example shift + ctrl + x.
UsbKeyboard.sendKeyStroke(KEY_B,MOD_CONTROL_LEFT) works, but
UsbKeyboard.sendKeyStroke(KEY_B,MOD_CONTROL_LEFT, KEY_ARROW_LEFT) does not work, and I get the following error message:
UsbKeyboardtest.ino: In function 'void loop()':
UsbKeyboardtest:41: error: no matching function for call to 'UsbKeyboardDevice::sendKeyStroke(int, int, int)'
D:\arduino-1.0.5-r2\libraries\UsbKeyboard/UsbKeyboard.h:153: note: candidates are: void UsbKeyboardDevice::sendKeyStroke(byte)
D:\arduino-1.0.5-r2\libraries\UsbKeyboard/UsbKeyboard.h:157: note: void UsbKeyboardDevice::sendKeyStroke(byte, byte)
I think it's got something to do with the following in Usbkeyboard.h:
void sendKeyStroke(byte keyStroke) {
sendKeyStroke(keyStroke, 0);
void sendKeyStroke(byte keyStroke, byte modifiers) {
while (!usbInterruptIsReady()) {
// Note: We wait until we can send keystroke
// so we know the previous keystroke was
// sent.
memset(reportBuffer, 0, sizeof(reportBuffer));
reportBuffer[0] = modifiers;
reportBuffer[1] = keyStroke;
I have already tried a few things, but my knowledge of C++ is very minimal, so it doesn't surprise me that it doesn't work. I need to add an extra modifier.
The only thing I want, is to send a ctrl + uppercase character, but since the HID tables only has lowercase, I need to send a shift too, and that's where it goes wrong.
I have only posted snippets of the code, I assume that others are in the know about this project.
For more complicated keys you will probably have to use a sequence of press and release calls.
Keyboard.press(KEY_LEFT_SHIFT);
Keyboard.press(KEY_LEFT_CTRL);
Keyboard.press('x');
delay(50);
Keyboard.releaseAll();
Wish it was that simple, if you send the commands 1by1, like in your example, it doesn't work.
And which key is generated by the sequence?
Which program are you using to displays the key?
It's a dedicated program, but got it sorted now, the solution was to use this command:
UsbKeyboard.sendKeystroke(KEY_X, MOD_CONTROL_LEFT | MOD_SHIFT_LEFT);
