question about URM37 V3.2
i’m testing URM37 v3.2 recently. below is the test result from the serial monitoring:
Distance=24098
Distance=24098
Distance=23842
Distance=24098
may anyone pls tell me how to convert the measurement unit ?i have tried using ‘microsecondsToInches’ and ‘microsecondsToInches’, but it seem like not valid. can anyone help me ?
Can you post the code you have sofar?
i have changed the sensor position and output value decrease accordingly. but the value i get is so confuse.
24098 is about 1.5m from the object.
/* Ultrasound Sensor
* URM V3.2 ultrasonic sensor TTL connection with Arduino
* Reads values (0-300) from an ultrasound sensor (3m sensor)
* and writes the values to the serialport.
* Pin12 (Arduino)-> Pin 1 VCC (URM V3.2)
* GND (Arduino) -> Pin 2 GND (URM V3.2)
* Pin11 (Arduino) -> Pin 7 (URM V3.2)
* Pin 0 (Arduino) -> Pin 9 (URM V3.2)
* Pin 1 (Arduino) -> Pin 8 (URM V3.2)
* www.yerobot.com
* Last modified 20/04/2009
int UREnable = 11; // Ultrasound enable pin
int URPower = 12; // Ultrasound power pin
int val = 0;
int USValue = 0;
int timecount = 0; // Echo counter
int ledPin = 13; // LED connected to digital pin 13
boolean flag=true;
uint8_t DMcmd[4] = { 0x22, 0x00, 0x00, 0x22}; //distance measure command
  Serial.begin(9600);                  // Sets the baud rate to 9600
  pinMode(ledPin, OUTPUT);            // Sets the digital pin as output
   pinMode(UREnable, OUTPUT);
   digitalWrite(UREnable, HIGH); // Set to High
    pinMode(URPower, OUTPUT);
   digitalWrite(URPower, HIGH); // Set to High
delay(200); //Give sensor some time to start up --Added By crystal  from Singapo, Thanks Crystal.
  flag=true;
  //Sending distance measure command :  0x22, 0x00, 0x00, 0x22 ;
  for(int i=0;i<4;i++)
    Serial.print(DMcmd[i],BYTE);
  delay(75); //delay for 75 ms
while(flag)
    if(Serial.available()>0)
        int header=Serial.read(); //0x22
        int highbyte=Serial.read();
        int lowbyte=Serial.read();
        int sum=Serial.read();//sum
        if(highbyte==255)
          USValue=65525;  //if highbyte =255 , the reading is invalid.
          USValue = highbyte*255+lowbyte;
       Serial.print("Distance=");
       Serial.print(USValue);
       flag=false;
  delay(50);
anyone hv the solution or any ideal share wif me ?
Please use code tags when you post code. It is the # button in the editor (if you modify your post and select the code and press # it will be done automatically)
try to replace:
    Serial.print(DMcmd,BYTE);
with
    Serial.write(DMcmd);
Then you write
You try to read 4 bytes, but you only know there are more than 0. So change this into
if(Serial.available()>=4)
optionally print all 4 bytes here for debug
should get you a step closer now
thx very much. nw i get the value in cm after changed the code to according to yr advice. But hw to set the max range. now the max range is 70 cm even the range is 1.5 m. The user guide stated that is can support up to 0.35cm to 3m (5m depend on the situation).
    Serial.write((byte)DMcmd[i]);
    //Serial.write(DMcmd);
and
You have the user guide. What does it tell about the max range? What does it state about the reflective surfaces needed?
Maybe your code divides by 2 where it is not needed? THe soundpulse does the distance twice?
According to http://www.dfrobot.com/wiki/index.php?title=URM37_V3.2_Ultrasonic_Sensor_(SKU:SEN0001) there is no surfaces requirement.I think my room space is enough for the Beam Width. I will go through more materiel over internet but the information is limited. Anyway thanks for the advise.
Did you get the temperature from the URM37? If so: how?
Another idea, maybe you are getting the distances in inches? That is also approx a factor 2 ...
