question about variable definition
Hi all,
I defined a global timeout value, to make the code more readable, I used following clause:
long TimeOutValue = 5 * 60 * 1000; // 5 mins
the compile passed, but when I run the code, the timer expired very quickly.
so I changed it to:
long TimeOutValue = 300000;
then, everything works fine.
is this a compiler issue?
other Info: -Board: 2009 -IDE: 0018
Regards, James
Try this...
const long TimeOutValue = 5L * 60L * 1000L; // 5 mins
It is very likely that unsigned long is the correct datatype...
const unsigned long TimeOutValue = 5UL * 60UL * 1000UL; // 5 mins
[edit]Revised per PaulS's suggestion.[/edit]
The l (for long) is typically written using a L, to make it easier to distinguish from a 1. The difference between 1 and l is hard to see in some fonts. The difference between 1 and L is always distinguishable.
