How can supply appropriate voltage&Current into Vin Port with 24V 5A Power supply
You'll need to knock the voltage down to the expected range of 7-12V for the Arduino through some external means. Look for a converter 24V->12V (or 24V->9V). There are plenty online.
You can't connect your power supply directly.
You cant. Max V on Vin is 12v. You need a buck converter to reduce the voltage. If you do that just go on down to +5 and use the 5V pin instead to bypass to onboard Vreg.
How do you think about using resister to solve this problem?
You're probably thinking about a resistor (or voltage) divider. There are several reasons why we don't typically do it this way - see link.
A resistor or resistive diivider will provide a voltage that depends on the current drawn.
You dont want that.
Simplest and safest solution - use a USB charger (AKA wall wart) tp provide 5V and use your big psu for something else.
What model Arduino are you using?
Thanks.. Tom..
