Question about voltage and current
My reference is this tutorial. http://arduino-for-beginners.blogspot.com/2011/04/controlling-12v-fan-speed-with-pwm.html
My concern is can I use the Vin pin of Arduino to be the 12v input of the fan. Because it is said in the blog. That I should use different 12V input. Is using the Vin of my Arduino can damage it?
By the way. I'm using a Universal AC/DC adaptor as my external input of my arduino. The voltage that it can produce is range froum 1.5V to 12V. Input: 220V~60Hz Output: 1.5-12V ("I don't know what is the symbol after this, but it is a line on top and three dots in the bottom" after that symbol..)500mA.
Thanks for helping me :)
I didn't see that in the blog, but there's no reason not to use the same 12v for both VIN and the fan.
DC or pulsed DC.
Rob
Graynomad: I didn't see that in the blog, but there's no reason not to use the same 12v for both VIN and the fan.
DC or pulsed DC.
Rob
It can't damage my Arduino? Thanks :) because I already done it with different input. And I'm afraid to try i with the same input. I thought it might damage my Arduino because i'm not using an IC like stepper driver in my stepper motor.
Not putting 12v into VIN no, but this worries me...
And this
If you are trying to drive a motor directly from the Arduino we're going to have a problem :)
Rob
Graynomad:
And this
Rob
So it does damage my Arduino?
I just copy the schematic in the blog that i post here. I use a 12v Fan.
So I had thoughts of you connecting a motor directly to the Arduino. That circuit uses a transistor so it's OK.
Rob
