I thought “was not declared in this scope” meant it was in another unindented section. Put another way, I thought everything inside void loop() was the same scope. Here’s some of the code that’s foul:
int packetSize = Udp.parsePacket();
if (packetSize) { // In this block, the ESP is handling the
IPAddress pySenderIP = Udp.remoteIP(); // commands sent over WiFi from the PC
Then further down I have:
if (Serial.available() > 0) { // Listen to Serial for ProMini's commands
len = Serial.readBytes(serialBuffer, 64);
serialBuffer[len] = 0; // (terminate the array)
if (serialBuffer[0] == 95) { // (asc(95) is just the symbol I chose to signal, "special case, do this instead")
Udp.beginPacket(pySenderIP, pySendrPort);
At this point, I get:
‘pySenderIP’ was not declared in this scope
despite having previously used it the same way earlier in the main loop.
What I’m trying to do is use an ESP8266 to pass data between a ProMini and a laptop PC. Communication is: PC<–>ESP using WiFi (UDP), and ESP<–>ProMini using UART (Serial. commands).
The ProMini can tell the ESP to request NTP time, as can the PC. When the ESP gets the NTP response, it always passes the timestamp to both the PC and the ProMini. So the trouble I’m running into is that the ESP has to use UDP to send packets to the NTP server as well as to the laptop. So I have two uses for Udp.beginPacket. The first I pasted from the NTPClient example:
void sendNTPpacket(IPAddress& address) {
... (stuff)
(stuff)...
udp.beginPacket(address, 123);
and the other is a more general form from other examples which use:
Udp.beginPacket(Udp.remoteIP(), Udp.remotePort());
The problem with this is that it sends the packet to the sender of the most recently received packet. This would return the incoming NTP packet back to the server. So I want to store the IP address when the laptop talks to the ESP. I found an example which seems to do this using:
IPAddress remoteIp = Udp.remoteIP();
which I replaced remoteIp with what I find much clearer, pySenderIP (I use Python on my laptop for UDP packets), which how I came up with this line in my code:
But this is where I get “‘pySenderIP’ was not declared in this scope”, even though it’s only 19 lines earlier in void loop()
Here are the above pieces in use:
The first time the laptop PC talks to the ESP, the ESP stores the laptop’s IP address in the variable pySenderIP. (first code snippet)
When the ESP gets a time request from the ProMini (ascii(95) in the second code snippet) the ESP initializes a UDP packet to the NTP server (third code snippet)
When the timestamp returns, the ESP wants to initialize a UDP packet to send the PC (sixth code snippet), as well as over Serial to the ProMini.
Whew! So here’s my entire void loop(), the actual request to the NTP server is a paste of the NTPClient example which is what the timeRequested() function does. The chrono array is just the 48 byte NTP packet trimmed down to 4 bytes for just the time.
if (packetSize) {
uint16_t pySendrPort = Udp.remotePort();
int n = Udp.read(incomingUdp, UDP_TX_PACKET_MAX_SIZE);
incomingUdp[n] = 0;
if (incomingUdp[0] == 95) {
timeRequested();
Udp.write(chrono);
Udp.endPacket();
Serial.println(chrono);
else {
Serial.println(incomingUdp);
timeRequested();
Udp.write(chrono);
Udp.endPacket();
else {
Udp.write(serialBuffer);
Udp.endPacket();
EDIT: I just realized there is a weakness in that I’m counting on not getting any NTP packets outside of the code which gets it (the example NTPClient which is called by my function timeRequested()). The example seems to not expect a response if one second goes by after making a request.
(for reference, from the example:)
sendNTPpacket(timeServerIP); // send an NTP packet to a time server
// wait to see if a reply is available
int cb = udp.parsePacket();
if (!cb) {
Serial.println("no packet yet");
Serial.print("packet received, length=");
Serial.println(cb);
// We've received a packet, read the data from it
udp.read(packetBuffer, NTP_PACKET_SIZE); // read the packet into the buffer
