I've been tasked by my work to build a simple tally light system, with 5 push buttons and 4 LEDs.
Essentially each pushbutton would kill all leds except the led corresponding to that button, and the off switch will turn all LEDs off. It needs to be spread over 2 rooms. I've done some drawings and would love to hear your thoughts about the design, and if I've missed anything obvious.
In terms of the connection between the control box and the junction box, do you think a DIN5 connection could work? 1 pin for ground and the rest for each of the 4 LEDs?
And when whomever starts thinking the 10mm LEDs are insufficient, you'll be in perfect shape for using opto-isolated drivers for larger, locally powered lamps…
Exactly! Wireless versions of this system go for 1700 Euro, so I figured I'd try make a lo-fi diy version, save some money and learn something along the way.
My wife accuses me of overengineering all of my projects.
I would do everything wireless. A Wemos D1 Mini with four buttons at the TD location, then an EPS01 with the tally LED at each camera location. Each push of a button would publish on/off messages to all of the tally ESP's. If you have individual monitors for each camera, you could stick another ESP01 there. You could even build a tally box for the floor director.
If your station is anything like the one I worked at, the switcher has a tally plug, probably an RS232 connector, that has dry-contact switch connections so when you take a new camera, you only have to press one button.
I’m all for adding features and so forth; sometimes there are things where one really has an immediate problem to solve.
Around here we are still waiting for someone to finish the garage door status monitor and alarm… meanwhile everyone has pretty much learned to not leave it open.
