QUESTION CUBE LED 8X8X8
Good nite i got a question about this code i wanna put some effect this is original code to start that cube..
     * Name    : LED CUBE 8x8x8 74HC595
     * By      :
    #include <TimerOne.h>
    #include <string.h>
    #define AXIS_X 1
    #define AXIS_Y 2
    #define AXIS_Z 3
    //--- Pin connected to ST_CP of 74HC595
    //--- Gelbe Leitung RCK
    int latchPin = 10;
    //--- Pin connected to SH_CP of 74HC595
    //--- Schwarze Leitung SCK
    int clockPin = 13;
    //--- Pin connected to DS of 74HC595
    //--- Lila Leitung SI
    int dataPin = 11;
    //--- Used for faster latching
    int latchPinPORTB = latchPin - 8;
    //holds value for all the pins, [x][y][z]
    byte cube[8][8];
    //Counts through the layers
    int current_layer = 0;
    //--- This process is run by the timer and does the PWM control
    void iProcess(){
      //last layer store
      int oldLayerBit = current_layer + 2;
      //increment layer count
      current_layer++;
      if(current_layer >= 8){
        current_layer = 0;
      //--- Run through all the shift register values and send them (last one first)
      // latching in the process
      latchOff();
      for (int i = 0 ; i < 8 ; i++){
        spi_transfer(cube[current_layer][i]);
      //Hide the old layer
      digitalWrite(oldLayerBit, LOW);
      //New data on the pins
      latchOn();
      //new layer high
      digitalWrite(current_layer + 2, HIGH);
    //--- Direct port access latching
    void latchOn(){
      bitSet(PORTB,latchPinPORTB);
    void latchOff(){
      bitClear(PORTB,latchPinPORTB);
    //--- Used to setup SPI based on current pin setup
    //    this is called in the setup routine;
    void setupSPI(){
      byte clr;
      SPCR |= ( (1<<SPE) | (1<<MSTR) ); // enable SPI as master
      SPCR &= ~( (1<<SPR1) | (1<<SPR0) ); // clear prescaler bits
      clr=SPSR; // clear SPI status reg
      clr=SPDR; // clear SPI data reg
      SPSR |= (1<<SPI2X); // set prescaler bits
      delay(10);
    //--- The really fast SPI version of shiftOut
    byte spi_transfer(byte data)
      SPDR = data;                    // Start the transmission
      loop_until_bit_is_set(SPSR, SPIF);
      return SPDR;                    // return the received byte, we don't need that
      //layer pins
      for(int i = 2; i < 10; i++)
        pinMode(i, OUTPUT);
      pinMode(latchPin, OUTPUT);
      pinMode(clockPin, OUTPUT);
      pinMode(dataPin, OUTPUT);
      digitalWrite(latchPin,LOW);
      digitalWrite(dataPin,LOW);
      digitalWrite(clockPin,LOW);
      //--- Setup to run SPI
      setupSPI();
      //--- Activate the PWM timer
      Timer1.initialize(100); // Timer for updating pwm pins
      Timer1.attachInterrupt(iProcess);
    void loop(){
      int i,x,y,z;
      while (true)
       //effect_random_filler(75,1);
//       effect_random_filler(75,0);
  //     effect_planboing(AXIS_Z, 700);
    //effect_planboing(AXIS_Y, 700);
      // effect_planboing(AXIS_X, 700);
       //effect_text(1000);
      // effect_random_sparkle();
       //effect_random_sparkle_flash (2, 50 ,500);
    //sineWave3d();
      space(100);
  space(100);
     //  effect_intro();
       //effect_blinky2();
     //  effect_wormsqueeze (2, AXIS_Z, -1, 100, 1000);
  //     sinelines(4000,10);
    //   side_ripples (300, 500);
      // mirror_ripples(600,400);
 //      quad_ripples (600,300);
   //    linespin(1500,10);
     // fireworks(10,20,500);  //10,30,500
//       effect_rand_patharound(200,500);
  //     effect_box_wamp(1000);
    //   effect_rain(100);
       //effect_boxside_randsend_parallel (AXIS_X, 0, 200, 1);
       //effect_boxside_randsend_parallel (AXIS_X, 1, 200, 1);
       //effect_boxside_randsend_parallel (AXIS_Y, 0, 300, 1);
       //effect_boxside_randsend_parallel (AXIS_Y, 1, 300, 1);
       //effect_boxside_randsend_parallel (AXIS_Z, 0, 600, 1);
       //effect_boxside_randsend_parallel (AXIS_Z, 1, 600, 1);
       //effect_axis_updown_randsuspend(AXIS_Z, 550,5000,0);
       //effect_axis_updown_randsuspend(AXIS_Z, 550,5000,1);
       //effect_axis_updown_randsuspend(AXIS_X, 550,5000,0);
        //effect_axis_updown_randsuspend(AXIS_X, 550,5000,1);
       //effect_axis_updown_randsuspend(AXIS_Y, 550,5000,0);
       //effect_axis_updown_randsuspend(AXIS_Y, 550,5000,1);
how i can put this is the effects on my cube??
0xf2,
0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01,
With a sledge hammer? What the heck IS that?
My guess would be:
byte *cubePtr = (byte *)cube;
for (int i=0; i<64; i++)
  *cubePtr++ = 0x01;
johnwasser:
My guess would be:
  *cubePtr++ = 0x01;
i wanna use this program on my cube this give me that code.. but idk how to put it on on my arduino code..
expfull:
It looks like the convention is to create a function called "effect_SOME_NAME()" and call it from loop(). Look at all of the other 'effect' functions to see how they do things.
