GoForSmoke:
edgaryo:
and is one more problem , is very very sensible . If i put the arduino in hand the led will be flash
. Why ? You can do a better program ?
Please
Something is shorted?
The power to the relay, is the ground of that connected to the ground of the Arduino before either is powered up?
Except where isolators are used, all grounds for all power should be connected.
Better program will take that you learn some ideas, like how to make things happen on time without stopping everything else.
This is a cleaned-up version of the Arduino Example Sketch, BlinkWithoutDelay.
I left the original comments in because it is Public Domain.
/* Blink without Delay -- with minor fixes by GFS
Turns on and off a light emitting diode(LED) connected to a digital
pin, without using the delay() function. This means that other code
can run at the same time without being interrupted by the LED code.
The circuit:
- LED attached from pin 13 to ground.
- Note: on most Arduinos, there is already an LED on the board
that's attached to pin 13, so no hardware is needed for this example.
created 2005
by David A. Mellis
modified 8 Feb 2010
by Paul Stoffregen
This example code is in the public domain.
http://www.arduino.cc/en/Tutorial/BlinkWithoutDelay
GFS fixes and modifications -- May 5 2013:
. changed time variables to be ALL unsigned longs, as they should be.
. added UL to numbers being assigned to unsigned longs as should be.
. changed the variable name 'interval' to 'blinkTime' as interval is now a
word used by the IDE, it shows up red (like the word 'if') instead of black.
. changed the if-else logic to change the ledState variable to 1 line XOR logic.
. added comments about adding more tasks to the sketch.
// constants won't change. Used here to
// set pin numbers:
const byte ledPin = 13; // the number of the LED pin
// Variables will change:
byte ledState = LOW; // ledState used to set the LED
unsigned long previousMillis = 0UL; // will store last time LED was updated
unsigned long blinkTime = 1000UL; // interval at which to blink (milliseconds)
// set the digital pin as output:
pinMode(ledPin, OUTPUT);
// here is where you'd put code that needs to be running all the time.
// GFS adds -- you see the if() { } block below? You can add more blocks
// whether if() or switch-case or whatever to do other tasks and as long
// as they run quick without delays or prolonged loops, your sketch will
// be responsive as if everything runs at the same time.
// just as the blink runs on time, another task can run when a button or
// sensor or serial data comes in or changes.
// simple commands run in less than a millionth of a second so you can pack
// a good bit of process into a block and still run quick. analog read takes
// longer, about 9 per millisecond so it's best not to do a bunch of those
// in a row but instead 1 analog read per time through loop() so other tasks
// can get a chance in between analog reads.
// it's also good to avoid using floating-point as that is slooowww and avoid
// using C++ Strings as they mess with your RAM and suck up CPU cycles doing it.
// Back to the original program:
// check to see if it's time to blink the LED; that is, if the
// difference between the current time and last time you blinked
// the LED is bigger than the interval at which you want to
// blink the LED.
if(currentMillis - previousMillis >= blinkTime) // is it time to change the led?
// save the last time you blinked the LED
// if the LED is off turn it on and vice-versa:
ledState = ledState ^ 1; // ^ is logical XOR, true if the values are different
// using logic operations can save a lot of tedious, pain to debug if's
// set the LED with the ledState of the variable:
digitalWrite(ledPin, ledState);
no, nothing is shorted , all is connected at ground .... i don't know why is so sensible ....
I will try to make a better program .
Thank you ! You helped me a lot !!!
