Question from a noob
Aparantly i have to do a normal post first
Hi im a bit new to arduino and its programming langauge, what im trying to do, is for now getting an led to turn on when a certain distance is reached. I am using a parallax ping ultrasonic sensor and on its own works perfectly,
this is the code so far
/* Ping))) Sensor
This sketch reads a PING))) ultrasonic rangefinder and returns the distance to the closest object in range. To do this, it sends a pulse to the sensor to initiate a reading, then listens for a pulse to return. The length of the returning pulse is proportional to the distance of the object from the sensor.
The circuit: * +V connection of the PING))) attached to +5V * GND connection of the PING))) attached to ground * SIG connection of the PING))) attached to digital pin 7
created 3 Nov 2008 by David A. Mellis modified 30 Jun 2009 by Tom Igoe
// this constant won't change. It's the pin number // of the sensor's output: const int pingPin = 7; const int ledPin = 13;
void setup() { // initialize serial communication: Serial.begin(9600); }
void loop() { // establish variables for duration of the ping, // and the distance result in inches and centimeters: long duration, inches, cm;
// The PING))) is triggered by a HIGH pulse of 2 or more microseconds. // Give a short LOW pulse beforehand to ensure a clean HIGH pulse: pinMode(pingPin, OUTPUT); digitalWrite(pingPin, LOW); delayMicroseconds(2); digitalWrite(pingPin, HIGH); delayMicroseconds(5); digitalWrite(pingPin, LOW);
// The same pin is used to read the signal from the PING))): a HIGH // pulse whose duration is the time (in microseconds) from the sending // of the ping to the reception of its echo off of an object. pinMode(pingPin, INPUT); duration = pulseIn(pingPin, HIGH);
// convert the time into a distance inches = microsecondsToInches(duration); cm = microsecondsToCentimeters(duration);
Serial.print(inches); Serial.print("in, "); Serial.print(cm); Serial.print("cm"); Serial.println();
delay(100); }
long microsecondsToInches(long microseconds) { // According to Parallax's datasheet for the PING))), there are // 73.746 microseconds per inch (i.e. sound travels at 1130 feet per // second). This gives the distance travelled by the ping, outbound // and return, so we divide by 2 to get the distance of the obstacle. // See: http://www.parallax.com/dl/docs/prod/acc/28015-PING-v1.3.pdf return microseconds / 74 / 2; }
long microsecondsToCentimeters(long microseconds) { // The speed of sound is 340 m/s or 29 microseconds per centimeter. // The ping travels out and back, so to find the distance of the // object we take half of the distance travelled. return microseconds / 29 / 2; }
My question is, is where do i put the "if" statement for having the led turn on and what would like it,
hope this is enough info to go on, and any help much appericiated
 Serial.print(cm);
 Serial.print("cm");
You are printing the values of cm and inches. After printing them would be a good place to use them.
if(inches > 42)
   // Turn the LED on
   // Turn the LED off
Thanks very much all is working now, ah now the endless possibilities
