question i am new with using Arduino uno
i am trying to use the dht11 sensor and i downloaded the dht.h library. whenever i try to upload the project it gives me this error thank you for helping
compilation terminated.
exit status 1
Error compiling for board Arduino/Genuino Uno.
option enabled in File -> Preferences.
It will give you more than likely more than that; place the cursor in the output window, select all text and post it here.
Also post the code.
For both, please use code tags
type
[/code]
paste your code or error after that
type [/code]
after that
Your code in the post will look like your code here
code (#include "DHT.h"
#include "LiquidCrystal.h"
#define DHTPIN 9
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
dht.begin();
lcd.begin(16,2);
lcd.print("The current temp");
lcd.setCursor(0,1);
lcd.print("is: ");
float f = dht.readTemperature(true);
lcd.setCursor(5,1);
lcd.print(f);
lcd.print(" F");
delay(1000605);
lcd.setCursor(5,1);
lcd.print(f);
lcd.print(" F");
this is the code i am using sorry i am new using this blog i dont understand it really good
sterretje:
Also post the code.
type
[/code]
type [/code]
after that
Your code in the post will look like `your code here`
[#include "DHT.h"
#define DHTPIN 9
dht.begin();
lcd.begin(16,2);
lcd.setCursor(0,1);
lcd.print("is: ");
lcd.setCursor(5,1);
lcd.print(f);
lcd.print(" F");
delay(1000*60*5);
lcd.setCursor(5,1);
lcd.print(f);
lcd.print(" F");
(error)
Arduino: 1.8.0 (Windows 7), Board: "Arduino/Genuino Uno"
In file included from C:\Program Files\Arduino\libraries\DHT.h\DHT_U.cpp:22:0:
C:\Program Files\Arduino\libraries\DHT.h\DHT_U.h:25:29: fatal error: Adafruit_Sensor.h: No such file or directory
#include <Adafruit_Sensor.h>
exit status 1
Invalid library found in C:\Program Files\Arduino\libraries\thermostat: C:\Program Files\Arduino\libraries\thermostat
Invalid library found in C:\Users\mguel\Documents\Arduino\libraries\thermostat: C:\Users\mguel\Documents\Arduino\libraries\thermostat
It's hard to imagine a clearer message.
