Question. Loop principle. 5 diodes
Hi, i have a problem with understanding a loop in couple with incremental function.
Here is a link that simmulates work of this one. LINK
I don’t understand why every new loop of blinks of diodes starts from n+1 diode (output pin).
int i;
int n;
  for(i=2;i<7;i++)
    pinMode(i,OUTPUT);
 for(n=1;n<6;n++)
  switch(n)
    case 1:
    digitalWrite(2,HIGH);
    digitalWrite(2,LOW);
     case 2:
    digitalWrite(3,HIGH);
    digitalWrite(3,LOW);
     case 3:
    digitalWrite(4,HIGH);
    digitalWrite(4,LOW);
     case 4:
    digitalWrite(5,HIGH);
    digitalWrite(5,LOW);
     case 5:
    digitalWrite(6,HIGH);
    digitalWrite(6,LOW);
Thank you.
_5diodes.ino (650 Bytes)
Your ‘case’ needs a ‘break’
Before you post your code, try placing your cursor in the IDE's source code window and pressing Ctrl-T. It will reformat your code to a common C style that's a little easier for all to read.
Or press
econjack: ... And pressing Ctrl-T....
Or cmd-t if you are on a Mac
totallnoob:
int i;
int n;
  for(i=2;i<7;i++)
    pinMode(i,OUTPUT);
for(n=1;n<6;n++)
  switch(n)
    case 1:
    case 2:
    case 3:
    case 4:
    case 5:
Thank you.
You’re kind of on the track, but the big switch shows you’re not :slight_smile:
  for(int i=2;i<7;i++) { // counts from 2 up to and including 6
    pinMode(i,OUTPUT);
  for (int i=2; i<7; i++) {
    digitalWrite(i,HIGH);
    digitalWrite(i,LOW);
:slight_smile:
you can even further “simplify” and use the loop function to get rid of the for iteration there
int currentLed;
    pinMode(i,OUTPUT);
 currentLed = 2;
    digitalWrite(currentLed,HIGH);
    digitalWrite(currentLed,LOW);
    if (++currentLed >= 7) currentLed = 2;
and if you are bold and understand in which sequence parameters get evaluated you can even go one step further and have only 1 digital write in the body and have the sequence work on the pin you tick only increments every 2 loops run
    digitalWrite(do_some_smart_math(&currentLed),!digitalRead(do_some_smart_math(&currentLed)));
J-M-L:
int currentLed;
    pinMode(i,OUTPUT);
currentLed = 2;
Yes that’s true, but for loops inside the loop() function, is more efficient, since they reduce the number of function calls. So there …
:smiley:
Rupert909: Yes that's true, but for loops inside the loop() function, is more efficient, since they reduce the number of function calls. So there ...
:-D
if you want to be really smart then in the loop you can play with PORTD and just shift a 1 around with bitwise operators (PORTD is for pins 0 to 7 so you'll need to mask the 2 lower bit to not touch them)
