Dear,
Got some problems in my recent code modification. The program hang after few call of a particular function and it look like Memory overflow or memory full error. But, this should not happen as I use local Variables.
Sometimes, the program may let me call 4-5 times the functions, other times, hang in the first call.
Symptoms : Everything freeze! not more processing nor LCD refresh.
This function is used to build a data string to be sent over Serial Port. The inputs are taken from an Array of String (Sensors Name) and an Array of Double (Data Value). The string is build in a "CSV" style to be received from the computer or my Internet Gateway.
I added lot of communications over serial to identify where the program hang and it's ALWAYS in this function. Mostly in the loop that build the string from the Sensors array. I suspect a memory full error but I don't understand why. Maybe I don't use correctly the String variables...
Any help, comment or suggestions would be really appreciated!.
Function in problem : BuildSensorString()
thanks!!
Mathieu
CODE (I removed not important code):
double Sensors[50];
String SENSORS_POINTNAME[NB_SENSORS] = {"TEMP1",
"TEMP2",
"TEMP3",
"TEMP4",
"TEMP5",
"TEMP6",
"TEMP7",
"TEMP8",
"LIGHTSENSOR",
"FLOWSENSOR",
"MAINVOLTAGESENSOR",
"MAINWATERVALVE",
"SECONDWATERVALVE",
"RELAY1",
"RELAY2",
"RELAY3",
"RELAY4",
"RELAY5",
"RELAY6",
"RELAY7",
"RELAY8",
"ALARM",
"STATUS",
"WATERPUMPAC"};
// BUILD a CSV Style string to send over Serial
// Format : $[String SensorName1];[String SensorValue1];[String SensorName2];[String SensorValue2]...#[CheckSum]#
String BuildSensorsString(){
Serial.print("Building Sensors DATASTRING.");
Buffer += '$';
for (int IDX = 0; IDX < NB_SENSORS; IDX ++) {
Serial.print('|');
Buffer = Buffer + SENSORS_POINTNAME[IDX] + ';' + DoubleToStr(Sensors[IDX],100);
Serial.print('-');
if (IDX < NB_SENSORS-1) Buffer = Buffer + ';';
Serial.print('.');
Buffer = Buffer + '#';
Serial.println(" DONE!");
Serial.print("Calculating Checksum... ");
Buffer = Buffer + String(Checksum(Buffer),DEC);
Serial.println("DONE!");
return Buffer;
// Function got from a forum to convert DOUBLE to STRING.
String DoubleToStr( double val, unsigned int precision){
// prints val with number of decimal places determine by precision
// NOTE: precision is 1 followed by the number of zeros for the desired number of decimial places
// example: printDouble( 3.1415, 100); // prints 3.14 (two decimal places)
//Serial1.print (int(val)); //prints the int part
String tmpStr = String(int(val));
if (precision > 0) {
//Serial1.print("."); // print the decimal point
tmpStr += ".";
unsigned int frac;
if(val >= 0)
frac = (val - int(val)) * precision;
frac = (int(val)- val ) * precision;
//Serial1.print(frac,DEC) ;
tmpStr += String(frac,DEC);
return tmpStr;
//Used to calculate a simple checksum for the string
byte Checksum(String tmpString) {
byte _CS = 0;
for (int idx=0; idx<tmpString.length(); idx++) {
_CS += tmpString[idx];
return _CS;
