question of the malfunction emergency stop of RC control car
I made 433MHz RC control car, few questions, sorry its too mess to upload some thing, just see if some one has the same experience:
  1. the car has an action lag when pushed the control joystick;
  2. heard may need a malfunction Emergency stop, just wonder how? software ? or maybe put another Arduino to oversee it?
Thanks
1 = probably bad programming (are you using readString() or similar on the receiving end with the 1s default timeOut)
  1. If you car gets out of range what happens ? Implementing a heart beat and motor stops if transmission is lost is not a bad idea
Without seeing the program it is very difficult to say anything useful.
I get my RC Tx to send a message at regular intervals, even if the data has not changed. Then the Rx can identify a transmission failure if a message fails to come within the time limit. I use nRF24l01+ transceivers but the concept is generally applicable.
If you are using the blocking readString() or similar to receive data then have a look at the examples in Serial Input Basics - simple reliable non-blocking ways to receive data. There is also a parse example to illustrate how to extract numbers from the received text.
...R
Thanks.
The code is here. It doesn't use the readString(),
#include <VirtualWire.h>
//motor A connected between A01 and A02
//motor B connected between B01 and B02
int STBY = 10; //standby  ////  An integer (more commonly called an int) is a number without a decimal point.
//Motor A
int PWMA = 3; //Speed control
int AIN1 = 9; //Direction
int AIN2 = 8; //Direction
//Motor B
int PWMB = 5; //Speed control
int BIN1 = 6; //Direction
int BIN2 = 16; //Direction  ////WAS16
const boolean FORWARD = HIGH; //
const boolean REVERSE = LOW;
float speed_Max = 255; //
float speed_Min = 0;
float analogInput_Max = 1023;  ////
float analogInput_Min = 0;
float analogInput_Middle_X = 515;//
float analogInput_Middle_Y = 495;//
float deadBand = 0;
float middleMax = (analogInput_Max / 2) + deadBand;
float middleMin = (analogInput_Max / 2) - deadBand;
boolean pastDirection = FORWARD;
void setup(){
	Serial.begin( 9600 );
	pinMode(STBY, OUTPUT); //
	pinMode(PWMA, OUTPUT);
	pinMode(AIN1, OUTPUT);
	pinMode(AIN2, OUTPUT);
	pinMode(PWMB, OUTPUT);
	pinMode(BIN1, OUTPUT);
	pinMode(BIN2, OUTPUT);
	//receiver setup
	vw_set_rx_pin(2);          //
	vw_set_ptt_inverted(true); //
	vw_setup(2000);            // Bits per sec
	vw_rx_start();             //
void loop(){
	uint8_t buf[VW_MAX_MESSAGE_LEN]; //
	uint8_t buflen = VW_MAX_MESSAGE_LEN;
	if (vw_get_message(buf, &buflen)) // Non-blocking
		int i;
	    int column = 0;
	    String message;
	    int commands[30];
        // Message with a good checksum received, dump it.
        for (i = 0; i < buflen; i++)
        	//DEBUG:
        	if(char(buf[i]) == '|'){  //
        		commands[column] = message.toInt();
        		message = "";
        		column++;
        	}else{
        		message += char(buf[i]);
        //one more time to capture the last value since the message does not end with |
        // DEBUG
//		Serial.print("X: ");
//		Serial.print(commands[0]);
//		Serial.print(" Y: ");
//		Serial.println(commands[1]);
		motorControl(commands[0], commands[1]);
void move(int motor, int speed, boolean direction){
	digitalWrite(STBY, HIGH); //disable standby //
	if(motor == 1){
		digitalWrite(AIN1, direction);
		digitalWrite(AIN2, !direction);
		analogWrite(PWMA, speed);   ///
	}else{
		digitalWrite(BIN1, !direction);
		digitalWrite(BIN2, direction);
		analogWrite(PWMB, speed);
void motorControl(float x, float y) {
	boolean currentDirection = y >= analogInput_Middle_Y;
	//map(value, fromLow, fromHigh, toLow, toHigh);
	if(currentDirection == REVERSE){
		y = map(y, analogInput_Middle_Y, analogInput_Min, speed_Min, speed_Max) ;
	}else{
		y = map(y, analogInput_Middle_Y, analogInput_Max, speed_Min, speed_Max);
	int subtractFromLeft = map(x, analogInput_Middle_X, analogInput_Min, speed_Min, y);
	int subtractFromRight = map(x, analogInput_Middle_X, analogInput_Max, speed_Min, y);
	if(subtractFromRight < 0){
		subtractFromRight = 0;
	if(subtractFromLeft < 0){
		subtractFromLeft = 0;
	int Throttle_RIGHT = y - subtractFromRight;
	int Throttle_LEFT = y - subtractFromLeft;
	boolean currentDirection_LEFT = currentDirection;
	boolean currentDirection_RIGHT = currentDirection;
	if(Throttle_LEFT < 1 && Throttle_RIGHT > 1){
		currentDirection_LEFT = !currentDirection; ////如果值为true,则!运算后为false
		Throttle_LEFT = Throttle_RIGHT;
	if(Throttle_RIGHT < 1 && Throttle_LEFT > 1){
		currentDirection_RIGHT = !currentDirection;
		Throttle_RIGHT = Throttle_LEFT;
	move(1, Throttle_LEFT, currentDirection_LEFT);
	move(2, Throttle_RIGHT, currentDirection_RIGHT);
would be good to see the sender as well
J-M-L:
Thank you.
//gamepad setup
int up_button = 2;
int down_button = 4;
int left_button = 5;
int right_button = 3;
int start_button = 6;
int select_button = 7;
int joystick_button = 8;
int joystick_axis_x = A0;
int joystick_axis_y = A1;
int buttons[] = {up_button, down_button, left_button, right_button, start_button, select_button, joystick_button};
	//gamepad setup
	for (int i; i < 7; i++)
		pinMode(buttons[i], INPUT);
		digitalWrite(buttons[i], HIGH);
	//transmitter setup
	vw_set_tx_pin(12);          // Sets pin D12 as the TX pin
	vw_set_ptt_inverted(true);  // Required for DR3100
int counter = 0;
int Xint;
int Yint;
char Xstr[60];
char Ystr[60];
	// Read and store Sensor  data
	Xint = analogRead(joystick_axis_x);
	Yint = analogRead(joystick_axis_y);
	// Convert integer data to Char array directly
	itoa(Yint,Ystr,10);
	itoa(Xint,Xstr,10);
	int XstrLength = String(Xstr).length();
	if(Xstr[XstrLength-1] != '|'){
		Xstr[XstrLength] = '|';
		Xstr[XstrLength+1] = '\0';
	char combinedArray[String(Xstr).length() + String(Ystr).length() + 1];
	sprintf(combinedArray, "%s%s", Xstr, Ystr);
	vw_send((uint8_t *)combinedArray, strlen(combinedArray));
	vw_wait_tx(); // Wait until the whole message is gone
	Serial.println(combinedArray);
for (int i; i < 7; i++)Oops
if you use sprintf(), why do you mess around with the String class...
your delays might come from lost messages if you operate in a noisy environment
AWOL:
Ya, just save some time if there are 20 buttons.
laoadam:
and an initial value for i, you think it's optional in that case?
J-M-L:
Thanks
How to correct it?
use for (byte i [color=red]= START_PIN[/color]; i < 7; i++) where START_PIN is 2,3,4 wherever you need to start
J-M-L:
Thanks,
Can you tell how to correct it?
J-M-L:
Thank you.
I'll change it.
laoadam:
Thanks,
yes I can. ;D :smiling_imp: :grin:
the doc of the function can help you too... give it a try and post your attempts
