Question on a 2x2x2 LED cube?
Hello i haven’t build a led cube in a while almost a year so thought i make one i found a simple 2x2x2 led cube single color using the uno board but was wondering how i can make it work on a attiny85 chip that only haves 5 pins but the code needs 6 can someone please help me out? the sketch is also below as to where i found the cube at.
website i found it at is Arduino 2x2x2 LED Cube with code - YouTube
int ledpins[] = {3,5,6,9};
int groundpins[] = {12,13};
void setup ()
  for(int i = 0; i < 4; i++)
      pinMode(ledpins[i],OUTPUT);
  for (int i= 0; i<2; i++)
  {pinMode(groundpins[i],OUTPUT);}
 twist();
 drop();
 diagonal();
void twist()
  int delaytime=100;
   digitalWrite(groundpins[0], HIGH);
    delay(100);
  digitalWrite(ledpins[0], HIGH);
  delay(delaytime);
  digitalWrite(ledpins[1], HIGH);
  delay(delaytime);
  digitalWrite(ledpins[2], HIGH);
  delay(delaytime);
  digitalWrite(ledpins[3], HIGH);
  delay(delaytime);
   digitalWrite(ledpins[0], LOW);
  delay(delaytime);
  digitalWrite(ledpins[1], LOW);
  delay(delaytime);
  digitalWrite(ledpins[2], LOW);
  delay(delaytime);
  digitalWrite(ledpins[3], LOW);
 delay(delaytime);
 digitalWrite(groundpins[0], LOW);
 digitalWrite(groundpins[1], HIGH);
    delay(100);
  delay(delaytime);
  delay(delaytime);
  delay(delaytime);
  delay(delaytime);
  delay(delaytime);
  delay(delaytime);
  delay(delaytime);
  delay(delaytime);
  digitalWrite(groundpins[1], LOW);
    delay(100);
  delay(delaytime);
  delay(delaytime);
  delay(delaytime);
  delay(delaytime);
  delay(delaytime);
  delay(delaytime);
  delay(delaytime);
  delay(delaytime);
    delay(100);
  delay(delaytime);
  delay(delaytime);
  delay(delaytime);
  delay(delaytime);
  delay(delaytime);
  delay(delaytime);
  delay(delaytime);
  delay(delaytime);
void drop()
  int dtime = 75;
  delay(dtime);
  digitalWrite(groundpins[1],HIGH);
  delay(dtime);
  delay(dtime);
  delay(dtime);
  delay(dtime);
  delay(dtime);
  delay(dtime);
  delay(dtime);
  //second time down
  delay(dtime);
  delay(dtime);
  delay(dtime);
  delay(dtime);
  delay(dtime);
  delay(dtime);
  delay(dtime);
  delay(dtime);
void diagonal()
 int dtime= 100;
 //bottom pin 0 on
 delay(dtime);
 //bottom pin 0 off
 delay(dtime);
 //top pin 1 on
 delay(dtime);
 //top pin 1 off
 //bottom pin 2 on
 delay(dtime);
 //bottom pin 2 off
  //top pin 3 on
 delay(dtime);
 //top pin 3 off
 //top pin 0 on
 delay(dtime);
 //top pin 0 off
 delay(dtime);
 //bottom pin 1 on
 delay(dtime);
 //bottom pin 1 off
 //top pin 2 on
 delay(dtime);
 //top pin 2 off
  //bottom pin 3 on
 delay(dtime);
 //bottom pin 3 off
You can use a shift register, they only need three pins, clock, data and latch.
Another option is charlieplexing.
I just thought of something i also have a attiny84 with 11 pin outs on it. might be better i just looked and had 2.
