Question on Ardnino Fio voltage output
I have a Fio with 3.3v output but i have a gryo ADXRS300 requires 5v seems like.
Would i be able to get the gryo working if i only have a fio?
Please help me out thank you
That chip is 5V only... Its full range output is from 1V to 4V which goes outside the 3V3 range. However it could be level-shifted using an op-amp circuit into the 0--3V3 range I suppose. (Or a resistor-divider circuit)
On the Gryo there is 2.5V, 5V, ground, and rate pins i need to use but in a fio there are only 3.3v pin. its there anyway i could use a gyro with fio?
thank you
