Question on Arduino Pro pinout
I've started working with an Arduino Pro to implement a designed I've worked out using an Uno R3. On the Uno, there are two sets of outputs for i2C (SCL & SDA) - A4 and A5 and also on last two (unmarked pins) after GND and VREF - in the corner near the reset button.
I can't seem to find where any of them are on the Pro! - and searching the web gets no real pin-outs for the Pro. Many for the Pro-Mini, but none for the Pro. And Sparkfun's docs are pretty useless as well in this area.
Any hints as to where SCL & SDA signals are located on the Arduino Pro?
=Alan R
If this is what you have A4 and A5 are your SDA and SCL:
See schematic:
Thanks for the link! I had gotten an early schematic - V12 and this one has the correct info.
=Alan R.
Harrzack:
They're the same, they just appear in two places. A multimeter will prove it.
Harrzack:
A4 and A5
