Question on battle bot program
hi, I am making a small scale battle bot after the show came on tv. I have an arduino mega with a seeed studio motor shield and a hc-06 bluetooth "chip". I programmed and wired everything but there is no output from the motor shield. I am a noob when it comes to programming so i would like your help. also I can connect my android phone to the blue tooth and the app I used worked before. The input in the app is 1,2,3,4 on a keyboard thanks, Will
Let me put on my magic hat and conjure up your code.
poof
There I have it.
As a starting point, please post your code.
Wait it do it post, sorry I will do that soon
*didn't
Still makes no sense.
If you don't have the code at hand to post, why bother replying?
#include “MotorDriver.h”
int Think = 2000; //Long delay time between steps
int Runtime = 5000; // How long Runtime actions will last
int Slow = 230; // slow speed (of 255 max)
int Fast = 255; // fast speed (of 255 max)
#include <SoftwareSerial.h>
SoftwareSerial BT(18, 19);
// creates a “virtual” serial port/UART
// connect BT module TX to D10
// connect BT module RX to D11
// connect BT Vcc to 5V, GND to GND
motordriver.init();
motordriver.setSpeed(200,MOTORB);
motordriver.setSpeed(200,MOTORA);
pinMode(13, OUTPUT);
// set the data rate for the SoftwareSerial port
BT.begin(9600);
// Send test message to other device
char a; // stores incoming character from other device
if (BT.available())
// if text arrived in from BT serial…
a=(BT.read());
if (a==‘1’)
motordriver.goForward();
delay(200);
motordriver.stop();
delay(100);
if (a==‘4’)
motordriver.goBackward();
delay(200);
motordriver.stop();
delay(100);
if (a==‘2’)
motordriver.goLeft();
delay(200);
motordriver.stop();
delay(100);
if (a==‘3’)
motordriver.goRight();
delay(200);
motordriver.stop();
delay(100);
PaulS:
If you don’t have the code at hand to post, why bother replying?
I forgot to attach it in the original post (pretty big fail) so i just posted it now.
Speaking of fail...
There is no excuse for trying to do software serial on hardware serial pins.
Also, go back and edit your post and put the code inside "code" tags. Read the "how to post to the forum" to learn how to do that. The more effort you put in, the more effort we will put in to support you.
PaulS: ``` // Send test message to other device
Speaking of fail...
SoftwareSerial BT(18, 19); ```
i've done it before
i've done it before
Why? The HardwareSerial class does it better.
