Hi all!
I'm using an arduino feather m0 to control(pwm) two N channel fets. One is regulating a TEC and the other is regulating a PC fan speed. I don't have any programming questions regarding that setup, however i do get a pretty nasty whine at low-to-mid speeds with the fan, and i'm reading this can be helped by altering the pins pwm frequency.
Currently using pins 10,11,12
10,12 are the fet signals
11 is a temp sensor
What is the base frequency for pwm on the m0?
Can i use setPwmFrequency on 10 or 12?
Will changing the frequency affect anything or any other pwm control i have going on or plan to use? (i do want to add a small oled readout)
Does setPwmFrequency revert back to base if i dont call it say in another sketch?
Thanks for any ideas!
