I have made a little program loop to make the robot move in a square. I may have messed up somewhere because it just goes in a straight line forever. One of the servos is on backwards and thats the only way that I could have done it. That is why the code has negatives in it. Thanks in advance for your help. Here is my code:
tfricks: And how do you control how far they go? Thanks that explains why I was having errors
Edit: I have continuous motion servos
Unless the last command position you send to the servo library was a 90 (or whatever the exact 'stop position' value for your specific servo is) the servo will turn continuously in one direction or the other depending on if the last value sent was larger or less then the stop value. The further the value is from the stop value the faster the servo will turn in that position.
PaulS:
Why are you attaching and detaching one of the servos in loop()? Why not both of them? Or, the more correct, none of them?
I agree, esp about detaching servos. A 'detached servo' is operating in a undefined state as no servo manufacture characterizes how their servo will behave with power applied but with no control pulses being sent, they are simply not designed to operate in that mode.
Some time back I tried the detach function with a servo, and the result was the servo behaved just like it was not connected to the arduino. Detaching a diy type of continuous rotation might be a handy thing.
