Question on ESP8266 library
Hi. I'm using the ESP8266-01 Wi-Fi module in my project and I have successfully compiled the code for FirebaseDemo. Now, I want to know how things have been done so I want to see the code for some functions like WiFi.begin(), WiFi.status() and WiFi.localIP(). In the FirebaseDemo sketch, only two header files are being included which are the <ESP8266WiFi.h> and the <FirebaseArduino.h>. So, I think the code for those functions will be defined in ESP8266WiFi.cpp. I searched in my PC for ESP8266WiFi.cpp and I found the following code:
#include "ESP8266WiFi.h"
extern "C" {
#include "c_types.h"
#include "ets_sys.h"
#include "os_type.h"
#include "osapi.h"
#include "mem.h"
#include "user_interface.h"
#include "smartconfig.h"
#include "lwip/opt.h"
#include "lwip/err.h"
#include "lwip/dns.h"
#include "debug.h"
// ---------------------------------------------------------- Debug ------------------------------------------------------
 * Output WiFi settings to an object derived from Print interface (like Serial).
 * @param p Print interface
void ESP8266WiFiClass::printDiag(Print& p) {
    const char* modes[] = { "NULL", "STA", "AP", "STA+AP" };
    p.print("Mode: ");
    p.println(modes[wifi_get_opmode()]);
    const char* phymodes[] = { "", "B", "G", "N" };
    p.print("PHY mode: ");
    p.println(phymodes[(int) wifi_get_phy_mode()]);
    p.print("Channel: ");
    p.println(wifi_get_channel());
    p.print("AP id: ");
    p.println(wifi_station_get_current_ap_id());
    p.print("Status: ");
    p.println(wifi_station_get_connect_status());
    p.print("Auto connect: ");
    p.println(wifi_station_get_auto_connect());
    struct station_config conf;
    wifi_station_get_config(&conf);
    char ssid[33]; //ssid can be up to 32chars, => plus null term
    memcpy(ssid, conf.ssid, sizeof(conf.ssid));
    ssid[32] = 0; //nullterm in case of 32 char ssid
    p.print("SSID (");
    p.print(strlen(ssid));
    p.print("): ");
    p.println(ssid);
    char passphrase[65];
    memcpy(passphrase, conf.password, sizeof(conf.password));
    passphrase[64] = 0;
    p.print("Passphrase (");
    p.print(strlen(passphrase));
    p.print("): ");
    p.println(passphrase);
    p.print("BSSID set: ");
    p.println(conf.bssid_set);
ESP8266WiFiClass WiFi;
The functions stated above are not in this file that I found on my PC. Then, I found another ESP8266WiFi.cpp on GitHub and here's the link: https://github.com/rogerclarkmelbourne/arduino-esp8266/blob/master/esp8266/libraries/ESP8266WiFi/src/ESP8266WiFi.cpp.
And from here, I saw someone posted the function prototype for the begin function but with different class name from what I found on GitHub.
So, my question is, which cpp file should I refer to if I want to see the code for functions like WiFi.begin(), WiFi.status() and WiFi.localIP()?
https://arduino-esp8266.readthedocs.io/en/latest/esp8266wifi/readme.html
I clicked on the first link, then libraries -> ESP8266WiFi -> src -> ESP8266WiFi.cpp
The content of ESP8266WiFi.cpp is same as what I found on my PC and it doesn't contain the definition for those function. Did I select the wrong file?
class ESP8266WiFiClass : public ESP8266WiFiGenericClass, public ESP8266WiFiSTAClass, public ESP8266WiFiScanClass, public ESP8266WiFiAPClass {
ESP8266WiFiSTAClass
OK, found it, thank you.
The WiFi in WiFi.begin() is an object right?
pauline95:
yes Arduino/libraries/ESP8266WiFi/src/ESP8266WiFi.cpp at 418b00f7c05d8658e265ff3246b508998423a14c · esp8266/Arduino · GitHub
