Question on Ethernet webclient and sending variables
I have a arduino sketch that will email a person using a php form that it calls by URL with the variables such as TO=user@domain.com&FROM=Me@domain.com
That all works
But what I want to do is take the a arduino variable from a sensor or another arduino function and use that in the Get statement
[b]int mBody = 5;[/b]
if (client.connect(serverName, 80)) {
    Serial.println("connected");
    // Make a HTTP request:
   client.println("GET /~genxweb/armail.php?TO=reciever@gmail.com&FROM=mike@me.net&SUBJECT=Test&MESSAGE=[b]mBody[/b]&CODE=SECRET HTTP/1.0");
    client.println();
    digitalWrite(ledIP, LOW);
    digitalWrite(ledMail, HIGH);
  else {
    // kf you didn't get a connection to the server:
    Serial.println("connection failed");
    digitalWrite(ledMail, LOW);
Here is a sample where I try to assign mBody a value of 5 and try to use that variable in the client.print and it will only send it as a string and not use the value. I read somewhere that I need to use string and define it but I am still learning and I dont understand the statement. I spent the last few hours on the forums trying to figure this out with no luck.
If I was doing this in Ruby a language I know I would put #{mBody} in the string and be good. Can some one shed some light on this.
Thanks in advance.
Don't use String. It's a memory hog.
Try this.
   client.print("GET /~genxweb/armail.php?TO=reciever@gmail.com&FROM=mike@me.net&SUBJECT=Test&MESSAGE=[b]); //CHANGED
   client.print(mBody); //ADDED
   client.println("[/b]&CODE=SECRET HTTP/1.0"); //ADDED
    client.println();
  else {
Now I am getting error 408 time outs. Verified the server is still up and the sketch works with original code as well still. I have done this:
int mBody = 5;
   client.print("GET /~genxweb/armail.php?TO=recieverb@gmail.com&FROM=mike@me.net&SUBJECT=Test&MESSAGE=");
   client.print("&CODE=SECRET HTTP/1.0");
   client.println();
I resolved this. Thanks for the help.
