Question on Switch case statement
Is it possible to use Boolean operators with case? something like below…
case 1 || 2:
do this;
and
case > 5 && < 10:
do this;
No.
you cam do lists of valueseg
case 1:
case 2:
case 3:
Mark
holmes4:
No.
case 1:
case 2:
case 3:
Mark
That's an OR, though: not sure if it's possible to do an AND?
JimboZA:
holmes4:
No.
case 1:
case 2:
case 3:
Mark
It's not possible to be more than one case at a time, so OR is all you need. His AND example was just a range greater than 5 and less then 10, so the values 6-9 satisfy it.
There's also the case range that gcc supports:
   case 2 ... 5:
simple example of the options of switch
int x;
  Serial.begin(115200);  // use fastest serial possible
  x = 0;
  x++;
  switch(x)
  case 0:
    Serial.println("zero");
  case 1 ... 9:
    Serial.println("between 1 and 9");
  case 10:
  case 11:
  case 13:
    Serial.println(x);
  case 15:
    x = 0;
  default:
    Serial.println(".");
Thank you all for your responses!
