question regarding input
Hi guys,
Im working on a small project, which basically runs a motor to pump fluid, until it detects that the liquid is leaking out of the container.
however, i have the motor working fine, it runs perfectly using the analogue output, so that i can control the flow based on the power output.
however the sensor is connected to input pin 3, and 5v+
now the problem is, when i run the script, pin 3 is bouncing HIGH, LOW, HIGH, LOW, HIGH, LOW but the connection isnt made, (the sensor isnt connected) so it is automatically stating that the system is leaking. why is pin 3 outputting power, when i have it set to input?
also, the if statement runs all the time, even when pin 3 is LOW (or 0) why?
here is the code
int z = 0;
pinMode(3, INPUT);
pinMode(15, OUTPUT);
while(z == 0)
analogWrite(15, 255);
Serial.println(“Pump Started”);
for(int x = 0; x <1000; x++)
if(digitalRead(3)==HIGH)
z = z+1;
Serial.println(“Leaked, Ending Test”);
Serial.println(digitalRead(3)); // shows 0 for 5 seconds then 1 for 5 seconds
Serial.println(z);
digitalWrite(15, LOW);
Serial.println(“Pump Stopped”);
guys i am a beginner so please be nice… lol. (script is not complete, as it does not end test, but just keeps going through it, i will sort that… but why is pin 3 doing what its doing.
cheers
keith
Your input is floating; use an pull-down resistor.
thanks,
I didnt realise i needed to add a pull down…
thanks for the help
keith
Or use the internal pullup resistor with pinMode(3, INPUT_PULLUP)
...R
