Question regarding pointers and char.
1) What is the difference between:
vw_send((uint8_t *)&msg, strlen(&msg)); vw_wait_tx();
AND
vw_send((uint8_t *)msg, strlen(msg)); vw_wait_tx();
2) What is the difference between: const char *msg AND char msg
1.
msg is an object, '&' returns the address of the object ( pointer ), then the pointer is cast to a uint8_t type pointer. strlen must accept a pointer.
The second version: the msg variable is already a pointer, it is just cast to the uint8_t type.
2.
char msg; This creates an object of type char accessed by its alias msg It will reside in the stack if used in a function ( automatic variable ), or in SRAM quota if in file or global scope.
char *msg; This creates a pointer that 'can' point to a char object, however at creation it doesn't point to anything valid.
char *msg = new char[ 4 ]; This is creating the same pointer, but also assigning a newly allocated memory location to it.
Once your pointer has data, its current location can be accessed using the '*' dereference operator. or as you can see the 'new' allocation creates 4 objects in an array.
Pointers and arrays are alike ( an array is a pointer managed by the system ).
*msg = 0; //Set first item to 0 msg[ 0 ] = 0 //Set first item to 0
*(msg + 1 ) = 5; //Set second item to 5 msg[ 1 ] = 5 //Set second item to 5
const char *msg; This is a pointer to a constant character. You cannot use this pointer to change the value being pointed.
EDIT:
char msg; char *msgptr = &msg;
This creates an object msg and sets its address as the pointer location for msgptr
thanks alot. Is there an error in the usage of char and pointer in the code given.
// Tx Code
// Wireless Force Sensor
// By Yaameen Faisal
#include <VirtualWire.h>              // Include VirtualWire library for wireless transmission
int fsrPin = 1;       // define pin A0 as FSR pin
int analog[8];        // define array to get multiple analog readings
int voltage[8];       // define array to get multiple voltage readings
int j;
int awakeCount = 0, restlessCount = 0, asleepCount = 0 ;  // define and initialise counters
  Serial.begin(9600);        // setup serial communication with baud rate (bits per second) to diplay on serial monitor
  vw_setup(2000);
  pinMode(fsrPin, INPUT);    // set pin A0 as input
  for(j=0; j<=7; j++)
    analog[j] = analogRead(fsrPin);                  // read pin A0, 8 times
    Serial.print("Analog Reading = ");
    Serial.print(analog[j],DEC);
    voltage[j] = map(analog[j], 0, 1023, 0, 5000);   // convert analog reading (0-1023) to voltage (0-5V)
    Serial.print(", Voltage in mV = ");
    Serial.print(voltage[j],DEC);
    if (voltage[j] >= 3500)                            //check if voltage >= 3500, if so restless counter = +1
      restlessCount = restlessCount + 1;
    else if (voltage[j] > 1500 && voltage[j] < 3500)  //check if 1500 < voltage < 3500, if so awake counter = +1
      awakeCount = awakeCount + 1;
    else if (voltage[j] > 100 && voltage[j] <= 1500)  //check if 100 < voltage <= 1500, if so asleep counter = +1
      asleepCount = asleepCount + 1;
    Serial.print(", Awake count = ");
    Serial.print(awakeCount, DEC);
    Serial.print(", Restless count = ");
    Serial.print(restlessCount, DEC);
    Serial.print(", Asleep count = ");
    Serial.println(asleepCount, DEC);
    delay (3000);
    int asleepcountLed = asleepCount;      // store asleep counter value in alseepcountLED
    int awakecountLed = awakeCount;     // store awake counter value in awakecountLED
    int restlesscountLed = restlessCount;   // store restless counter value in restlesscountLED
    Serial.println("-----------------------------------------------------------------------");
    if (asleepcountLed > awakecountLed && asleepcountLed > restlesscountLed)         // if asleep > awake & asleep > restless, led = green colour
      char data = 'g';
      vw_send((uint8_t *)&data, strlen(&data));
      vw_wait_tx();
    asleepCount = 0;       // reset asleep counter
    awakeCount = 0;       // reset awake counter
    restlessCount = 0;    // reset restless counter
    delay (500);
// Rx Code
#include <VirtualWire.h>                // include Virtualwire library for wireless transmission
  pinMode(4, OUTPUT);
  vw_set_rx_pin(8);
  vw_setup(2000);
  vw_rx_start();
  uint8_t buf[VW_MAX_MESSAGE_LEN];
  uint8_t buflen = VW_MAX_MESSAGE_LEN;
  if (vw_get_message(buf, &buflen))
    if (buf[0] == 'g')
	digitalWrite(4, HIGH);
    else if (buf[0] != 'g')
        digitalWrite(4, LOW);
The syntax is fine, its the subtleties that are hard to find,
strlen counts a string, which is null terminated. You pass it a single char. Replace the strlen with a literal 1 as you know the length.
To use the strlen function you will need something like
char data[] = { 'g', '\0' };
vw_send((uint8_t *)data, strlen(data)); //no & operator as data is an array and direct array access is a pointer to the first object.
It doesn’t seem to work either. When I use this simple code it turns the led ON. But when I use the previous code it still doesn’t work. Any suggestion or reason.
//transmitter Code
  Serial.println("Activated");
  vw_setup(2000);
  vw_set_tx_pin(8);
    char data[] = { 'b', '\0' };
    vw_wait_tx();
//receiver code
  //vw_set_ptt_inverted(true);
  vw_set_rx_pin(8);
  vw_setup(2000);
  vw_rx_start();
  pinMode(4, OUTPUT);
    if (buf[0] == 'a') {
    if (buf[0] == 'b') {
vw_get_message(buf, &buflen);
The function may expect an int for buflen, you pass its address, when converted to an integer it could be quite a large number.
Ok, what correction should I make? I'm not very pro in programming. At the moment I am pretty much lost and stuck. So, if you can, can you please let me know what correction I should make.
Thanks
But that simple code does work, why is it?
the code will fail when the buffer size is less than &buflen and the data received is more than the buffer size. pass the actual value, not the address.
Also what isn't working, if the code you had worked.
@pYro_65: Can you please take a look at this thread and help me out.
http://arduino.cc/forum/index.php/topic,94944.15.html
