Question regarding substring. Please Help :(
Hi, I wanted to split string accordingly before sending. I am learning about substring from this video Arduino Tutorial # 4.5: Better Serial Parsing - YouTube . I wanted to split string +IPD,0,2:#1.1.1s by just extracting #1.1.1s\n, so based on the video, my part1= com.substring(0, com.indexOf("#")); while part 2 = com.substring(com.indexOf("#"), com.indexOf(" "));
Here's my code:
#define esp8266 Serial3
String command;
long int previousMillis=0, currentMillis;
esp8266.begin(9600);
currentMillis = millis();
if( (currentMillis - previousMillis) > 500)
esp8266.print("+IPD,0,2:#1.1.1s\n");
if(Serial.available())
char c = Serial.read();
command += c;
parseCommand(command);
command = "";
void parseCommand(String com)
String part1;
String part2;
//TAKE A LOOK FROM HERE!! HELP :frowning:
part2 = com.substring(com.indexOf("#"), com.indexOf(" "));
Serial.print(part2);
I printed out part2 and it printed out # only. I thought should be #1.1.1s since the video tutorial mention that com.substring(from, up to) ?
Really frustrated. Please help :frowning:
Stop investing time using the String class - you'll get frustration later on with possibly memory issues
if your buffer holds char cmd[] = "+IPD,0,2:#1.1.1s\n" and you want the final part then the pointer to the string you are interested in is just (cmd+10) if the format is fixed
const char msg[] = "+IPD,0,2:#1.1.1s\n";
  Serial.println(msg);
  Serial.println(msg + 10); // if format is really known, start at position 10
  Serial.println(msg + (strlen(msg) - 7)); // to print the last 7 chars
  Serial.println(strchr(msg, '#')+1); // to print from 1st char after the #
void loop() {}
will print out to your console
+IPD,0,2:#1.1.1s
1.1.1s
1.1.1s
1.1.1s
things worth looking at:
stdlib.h
string.h
Serial Input Basics
Hi J-M-L
Thanks so much for replying.
The "+IPD,0,2:#1.1.1s\n" is coming from another serial (another arduino) through UART communication.
So it need to go through Serial.read()
So, const char c[] = Serial.read() ?
Then Serial.println(c);
Serial.println(msg +10);
and so on?
well build the cmd buffer by reading from your secondary Serial until your read the \n
for that read the Serial Input Basics link from previous answer - it also shows how to parse for content
The Serial object also knows how to perform a few basic stuff, like find, findUntil, readBytesUntil etc.... but it's a great exercise to implement for yourself
if I were you, I'd read the Serial input and drop the chars until I get the '#', then read and save the incoming chars one after the other in the cmd buffer until I get the '\n'.
--> live parsing as things come in
really read the Serial Input Basics link, it will all become super clear :slight_smile:
Dear J-M-L,
My problem is solved. Thank you so much for taking some time to reply my post and introduce me many useful references. I truly appreciate it. I thank you from the bottom of my heart and God bless you :slight_smile:
great - with pleasure!
