Question regarding the control of 24 individual switches
Hi Everyone,
I have a question that deals with sequentially controlling 24 SPST analog switch(ADG1412) for sourcing 24 different LEDs. I’m mostly concerned with the advantages/disadvantages of using a GPIO expander or simply running 24 different wires from my ATMEGA2560.
My goal is to maintain low power within my whole design (<4W) but I need to compare this to the ease of using 2 MCP23017 or simply turning the pins on and off from the ATMEGA. The 2 MCPs add about 10mW, this takes up a lot. I do have the option of increasing to about 6W but would rather not lower the bar.
Just looking for some advice or direction. Thanks in advance.
Using a multiplexed analogue switch to drive a LED is just plane stupid. Use a port expander every time.
Grumpy_Mike: Using a multiplexed analogue switch to drive a LED is just plane stupid.
It seems he was having a flight of fancy. :grinning:
Grumpy_Mike: Using a multiplexed analogue switch to drive a LED is just plane stupid. Use a port expander every time.
My description is a bit off. My LEDs are driven by high current output op-amp and my switches simply direct to each one.
Can you explain why I should always use an expander?
I appreciate it.
ThreeDMD: My LEDs are driven by high current output op-amp and my switches simply direct to each one.
Why drive leds with op-amps? And what are the switches directing? Some signal to the op-amp inputs, or the op-amp outputs to the leds? What are the input signals to the op-amps?
ThreeDMD: Can you explain why I should always use an expander?
Its simpler. Right now we don't understand the reasons for all your op-amps and switches, so that approach sounds over-complicated.
Have you considered shift registers? There are high-current ones available like tpic6c595.
PaulRB: Have you considered shift registers? There are high-current ones available like tpic6c595.
TPIC6*B595s or the highest current are TPIC6A*595s. But yes, for simple LEDs, the lower-rated TPIC6C595 would generally suffice.
These combine the function of "port expander" and current driver and are obviously the proper way to perform this function - only three port pins used to control 24 (or in fact, 128) LEDs. Of course, the LEDs require current limiting resistors.
Clearly absurd, but out of curiosity, just what "op-amps" were you proposing to use?
ThreeDMD: The 2 MCPs add about 10mW, this takes up a lot.
Mmm, no you got that wrong, it would be 10 µW. Pages 1 and 26 of the datasheet, parameter D005; Standby current.
