Question regarding why these motors are not spinning
Dumb question; I am trying to have these motors for 2 seconds run when the button is not pressed. I think I have everything wired up right and that my code is working.
//DataSlate
int buttonState = 0;
int speaker = 9;
//digitalWrite(LED_BUILTIN, HIGH);
//L293D Motor A
int motorPin1  = 5;
int motorPin2  = 6;
//L293D Motor B
int motorPin3  = 11;
int motorPin4  = 10;
pinMode(2, INPUT);
pinMode(LED_BUILTIN, OUTPUT); //used to test functionality of code
//Motors
pinMode(motorPin1, OUTPUT);
pinMode(motorPin2, OUTPUT);
pinMode(motorPin3, OUTPUT);
pinMode(motorPin4, OUTPUT);
  buttonState = digitalRead(2);
  if (Serial.available () > 0) {
  	String command = Serial.readStringUntil('\n');
    //Signal is standing in for a command signal from an external device
      if (command == "signal"){//A3
      	for (long i = 0; i < 2048 * 3; i++ )
    //ouchy ear noise
    digitalWrite(speaker, HIGH);
    delayMicroseconds(500);
    digitalWrite(speaker, LOW);
  //main process
  if (buttonState == HIGH){
    //nothing happens as user stopped action
    delay(10);
  } else if (buttonState == LOW){
    //User did not cancel action window will now open.
	digitalWrite(motorPin1, HIGH);
    digitalWrite(motorPin2, HIGH);
    digitalWrite(motorPin3, HIGH);
    digitalWrite(motorPin4, HIGH);
    delay(2000);
}//1
The speaker portion of this is working, but I think I am missing something with the controller.
Thanks in advance for the help.
What is your question?
PP3 NO2
I'd suuggest you check this page out
then clarify in your code what you expect these lines
to do
