Question serial.print
For a project i have to send "A0" (The letter and the number) from a Master using TX/RX and receive it on the slave and use the value in a switch case like
switch(value){ case A0;
//do something break; }
On the slave with the terminal i receive A0 (thats ok) but i'm not able to use it in the switch case.
Thanks for your help!
I believe A0 is 14, to be sure, try: Serial.print(A0);
Without seeing your code it is impossible to say what the problem is.
Have a look at serial input basics.
...R
Master :
void loop(){
Serial.print(C12); }
Slave :
void loop(){
while(Serial.available()>0){ int value = Serial.read();
switch(value){
case 'C12':
Thanks!
All the code, please. Use code tags
case 'C12':
Single quotes for a single character. You can't jam 3 characters into there. For three characters you need a string, and then you can't use switch / case.
Also, Serial.read() reads one character. If you want three characters, you'll have to call it three times and combine them in an array or in three different variables.
Serial.print(C12);
Do you have a variable C12 somewhere in the code?
If not, then this is going to give you a not declared in this scope error.
If you want to send the three characters C and 1 and 2, then you need to use a string.
Serial.print("C12");
