question C.. peut'etre mais n'est il pas posible de colé directement un module comme ceux que l'on utilise pour programer les uno pro , il y aurai ceu qu'il faut non ?
bonsoir
ce ne sont qu'un emetteur et un recepteur 434
tu l'utilise avec le protocole que tu veux
sous arduino
pour faire de la comm , tu peux regarder Virtualwire
oui merci j'ai trouvé la librairie manchester.zip pour faire une com. entre un arduino et un attiny ,ca compile pour l'arduino mais pas pour l'attiny.
j'ai suivit ca Home - Arduino Manchester Encoding - Mchr3k
et ça me renvoi ces erreurs :
/root/sketchbook/libraries/Manchester/Manchester.cpp:390:5: error: 'TCCR2A' was not declared in this scope
TCCR2A = _BV(WGM21); // reset counter on match
/root/sketchbook/libraries/Manchester/Manchester.cpp:390:21: error: 'WGM21' was not declared in this scope
/root/sketchbook/libraries/Manchester/Manchester.cpp:395:7: error: 'TCCR2B' was not declared in this scope
TCCR2B = _BV(CS21) | _BV(CS20); // 1/32 prescaler
/root/sketchbook/libraries/Manchester/Manchester.cpp:395:23: error: 'CS21' was not declared in this scope
/root/sketchbook/libraries/Manchester/Manchester.cpp:395:39: error: 'CS20' was not declared in this scope
/root/sketchbook/libraries/Manchester/Manchester.cpp:396:7: error: 'OCR2A' was not declared in this scope
OCR2A = (128 >> speedFactor) - 1;
/root/sketchbook/libraries/Manchester/Manchester.cpp:403:5: error: 'TIMSK2' was not declared in this scope
TIMSK2 = _BV(OCIE2A); // Turn on interrupt
/root/sketchbook/libraries/Manchester/Manchester.cpp:403:21: error: 'OCIE2A' was not declared in this scope
/root/sketchbook/libraries/Manchester/Manchester.cpp:404:5: error: 'TCNT2' was not declared in this scope
TCNT2 = 0; // Set counter to 0
/root/sketchbook/libraries/Manchester/Manchester.cpp: In function 'void TIMER2_COMPA_vect()':
/root/sketchbook/libraries/Manchester/Manchester.cpp:479:99: warning: 'TIMER2_COMPA_vect' appears to be a misspelled signal handler [enabled by default]
ISR(TIMER2_COMPA_vect)
on trouve tout et son contraire a ce propos.
apparement il y a des fichiers qui ne sonts pas au bon endroit.
oui je pense.
j'ai trouvé ca entre temps : http://forum.snootlab.com/viewtopic.php?t=875
un gars dans les commentaires a eu le meme prob. que moi dans les commentaires,
mais ca ne m'avance pas plus que ça.
Oui merci mais ca ne fonctionne toujours pas donc j'ai entrepris de le
faire sans librairies.
j'en suis au timer,mais a la base il y a quelque chose que je ne comprend pas
avec ces modules rf.
si je force l'entrée de l’émetteur a 1 ,en réception le "1" apparaitra bien mais pas constamment et ponctué de "0" donc pas net du tout comme fonctionnement.
aurait tu des info?
Merci.
