Question: testing Lora RFM95 module for send/receive
I have only 1 RFM95 module and I would like (for test purposes) to simultaneously send and receive messages using the same module. I am using the code for duplex Lora communication that comes with the lora library. I set the message destination to be like the source (see code below).
  LoRa Duplex communication
  Sends a message every half second, and polls continually
  for new incoming messages. Implements a one-byte addressing scheme,
  with 0xFF as the broadcast address.
  Uses readString() from Stream class to read payload. The Stream class'
  timeout may affect other functuons, like the radio's callback. For an
  created 28 April 2017
  by Tom Igoe
#include <SPI.h>              // include libraries
#include <LoRa.h>
const int csPin = 15;          // LoRa radio chip select
const int resetPin = 0;       //D3 LoRa radio reset
const int irqPin = 4;         //D2 change for your board; must be a hardware interrupt pin
String outgoing;              // outgoing message
byte msgCount = 0;            // count of outgoing messages
byte localAddress = 0xBB;     // address of this device
byte destination = 0xBB;      // destination to send to
long lastSendTime = 0;        // last send time
int interval = 2000;          // interval between sends
  Serial.begin(9600);                   // initialize serial
  while (!Serial);
  Serial.println("LoRa Duplex");
  // override the default CS, reset, and IRQ pins (optional)
  LoRa.setPins(csPin, resetPin, irqPin);// set CS, reset, IRQ pin
  if (!LoRa.begin(915E6)) {             // initialize ratio at 915 MHz
    Serial.println("LoRa init failed. Check your connections.");
    while (true);                       // if failed, do nothing
  Serial.println("LoRa init succeeded.");
  if (millis() - lastSendTime > interval) {
    String message = "HeLoRa World!";   // send a message
    sendMessage(message);
    Serial.println("Sending " + message);
    lastSendTime = millis();            // timestamp the message
    interval = random(2000) + 1000;    // 2-3 seconds
  // parse for a packet, and call onReceive with the result:
  onReceive(LoRa.parsePacket());
void sendMessage(String outgoing) {
  LoRa.beginPacket();                   // start packet
  LoRa.write(destination);              // add destination address
  LoRa.write(localAddress);             // add sender address
  LoRa.write(msgCount);                 // add message ID
  LoRa.write(outgoing.length());        // add payload length
  LoRa.print(outgoing);                 // add payload
  LoRa.endPacket();                     // finish packet and send it
  msgCount++;                           // increment message ID
void onReceive(int packetSize) {
  if (packetSize == 0) return;
  // if there's no packet, return
  // read packet header bytes:
  int recipient = LoRa.read();          // recipient address
  byte sender = LoRa.read();            // sender address
  byte incomingMsgId = LoRa.read();     // incoming msg ID
  byte incomingLength = LoRa.read();    // incoming msg length
  String incoming = "";
  while (LoRa.available()) {
    incoming += (char)LoRa.read();
  if (incomingLength != incoming.length()) {   // check length for error
    Serial.println("error: message length does not match length");
    return;                             // skip rest of function
  // if the recipient isn't this device or broadcast,
  if (recipient != localAddress && recipient != 0xFF) {
    Serial.println("This message is not for me.");
  // if message is for this device, or broadcast, print details:
  Serial.println("Received from: 0x" + String(sender, HEX));
  Serial.println("Sent to: 0x" + String(recipient, HEX));
  Serial.println("Message ID: " + String(incomingMsgId));
  Serial.println("Message length: " + String(incomingLength));
  Serial.println("Message: " + incoming);
  Serial.println("RSSI: " + String(LoRa.packetRssi()));
  Serial.println("Snr: " + String(LoRa.packetSnr()));
The results is that sent messages "HeLoRa World!" are not received by the module. I wonder if I can play on the timing of send/receive to get the message ?
Any suggestion is appreciated.
Unfortunately the Lora unit is not setup so it can simultaneously Tx and Rx a signal on the same channel.
Your best try is to buy a second Lora unit.
Tom... :smiley: :+1: :coffee: :australia:
The RFM95 LoRa modules cannot send and receive at the same time.
