Question to the programmers here about objects
Ok so I was talking to my professor about coding for my project and I asked if Objects was a good approach to it (A object for each component to help me organize it). But he suggested structs for it(he mentioned the over head wasn’t worth it for a project as simple as mine), and I know structs are just a form of objects(for C) before C++. Now he has never done programming for an Arduino so I wanted to ask you guys which approach would be better. A struct approach or a object approach, for lets say a ping sensor and all of it’s functions I would use for it.
Your professor is wrong. Using classes / objects has the exact same “overhead” as using structures. Until you add polymorphism (virtual methods). And, even then, the minor overhead is worth the benefit.
They are still a form of class / object. In C++ the only difference between struct and class is the default access level (public for struct; private for class).
[sarcastic comment removed]
Use classes / objects. Stay away from new / delete. Keep your constructor as simple as possible. Include a public method named “begin” that performs that actually initialization; call “begin” in the Sketch setup function. Use HardwareSerial / Serial as an example.
Well I figured my approach would be right (but I always go to OO since that's what I learned when I was in 6th grade). But thanks for the input, I can keep all my code (...well mostly gotta clean up my controller code).
