Hello, I once asked a question about using the Wire library from Arduino to communicate via SMBus a while back and with the help of fellow members I was able to get it working... to an extent.
Reading from the smart Li-ion battery is a success and now I am trying to write to the smart battery but the register I am trying to write to is confusing me. The datasheet states SMBus protocol: Write Word which if I am correct is 16 bits (2 Bytes), and then the datasheet proceeds to breakdown the 16 bits. This is very helpful except I don't know how to Wire.write to this breakdown of the 16 bits. Currently reading the register after writing to it yields the same bits as before.
Could someone help me? The datasheet is below if you want to skim through it, as well as the code I use to read and write.
sbdat110.pdf (138.8 KB)
#include <Streaming.h>
#include <Wire.h>
#define Addr_BATTERY_ADDRESS 0x0B // Replace with the correct battery address
#define Addr_ManufacturerAccess 0x00
#define Addr_RemainingCapacityAlarm 0x01
#define Addr_RemainingTimeAlarm 0x02
#define Addr_BatteryMode 0x03
#define Addr_AtRate 0x04
#define Addr_AtRateTimeToFull 0x05
#define Addr_AtRateTimeToEmpty 0x06
#define Addr_AtRateOK 0x07
#define Addr_Temperature 0x08
#define Addr_Voltage 0x09
#define Addr_Current 0x0a
#define Addr_AverageCurrent 0x0b
#define Addr_MaxError 0x0c
#define Addr_RelativeStateOfCharge 0x0d
#define Addr_AbsoluteStateOfCharge 0x0e
#define Addr_RemainingCapacity 0x0f
#define Addr_FullChargeCapacity 0x10
#define Addr_RunTimeToEmpty 0x11
#define Addr_AverageTimeToEmpty 0x12
#define Addr_AverageTimeToFull 0x13
#define Addr_ChargingCurrent 0x14
#define Addr_ChargingVoltage 0x15
#define Addr_BatteryStatus 0x16
#define Addr_CycleCount 0x17
#define Addr_DesignCapacity 0x18
#define Addr_DesignVoltage 0x19
#define Addr_SpecificationInfo 0x1a
#define Addr_ManufactureDate 0x1b
#define Addr_SerialNumber 0x1c
#define Addr_ManufacturerName 0x20
#define Addr_DeviceName 0x21
#define Addr_DeviceChemistry 0x22
#define Addr_ManufacturerData 0x23
#define SMBUS_DATA_1 18
#define SMBUS_CLCK_1 19
float batt_volt;
float batt_mode;
bool rwBit_0;
bool rwBit_1;
bool rwBit_2;
bool rwBit_3;
bool rwBit_4;
bool rwBit_5;
bool rwBit_6;
bool rwBit_7;
bool rwBit_8;
bool rwBit_9;
bool rwBit_10;
bool rwBit_11;
bool rwBit_12;
bool rwBit_13;
bool rwBit_14;
bool rwBit_15;
void readBatteryVoltage() {
// Request voltage data from the battery
Wire.beginTransmission(Addr_BATTERY_ADDRESS);
Wire.write(Addr_Voltage); // Voltage register address
Wire.endTransmission(false);
Wire.requestFrom(Addr_BATTERY_ADDRESS, 2);
if (Wire.available()) {
// Read voltage data
uint16_t voltage = Wire.read();
voltage |= Wire.read() << 8;
// Convert the raw data to voltage value
batt_volt = voltage / 1000.0;
Serial << "Battery Volt: " << batt_volt << " volts" << endl;
else{
batt_volt = batt_volt;
void writeBatteryMode() {
Wire.write(Addr_BatteryMode); // batt Mode register address
Wire.write(1);
Wire.endTransmission();
// if (Wire.available()){
// Wire.write(1, 2);
// //Wire.write(0x01);
void readBatteryMode() {
// Request relative state of charge data from the battery
int16_t mode;
if (Wire.available()>= 2) {
// Read Battery Mode data
mode = Wire.read();
mode |= Wire.read() << 8;
//rwBit_0 = mode & (0x01); // bit 0
rwBit_0 = bitRead(mode, 0);
rwBit_1 = bitRead(mode, 1);
rwBit_2 = bitRead(mode, 2);
rwBit_3 = bitRead(mode, 3);
rwBit_4 = bitRead(mode, 4);
rwBit_5 = bitRead(mode, 5);
rwBit_6 = bitRead(mode, 6);
rwBit_7 = bitRead(mode, 7);
rwBit_8 = bitRead(mode, 8);
rwBit_9 = bitRead(mode, 9);
rwBit_10 = bitRead(mode, 10);
rwBit_11 = bitRead(mode, 11);
rwBit_12 = bitRead(mode, 12);
rwBit_13 = bitRead(mode, 13);
rwBit_14 = bitRead(mode, 14);
rwBit_15 = bitRead(mode, 15);
Serial << rwBit_15 <<
rwBit_14 <<
rwBit_13 <<
rwBit_12 <<
rwBit_11 <<
rwBit_10 <<
rwBit_9 <<
rwBit_8 <<
rwBit_7 <<
rwBit_6 <<
rwBit_5 <<
rwBit_4 <<
rwBit_3 <<
rwBit_2 <<
rwBit_1 <<
rwBit_0 << endl;
else {
rwBit_14 <<
rwBit_13 <<
rwBit_12 <<
rwBit_11 <<
rwBit_10 <<
rwBit_9 <<
rwBit_8 <<
rwBit_7 <<
rwBit_6 <<
rwBit_5 <<
rwBit_4 <<
rwBit_3 <<
rwBit_2 <<
rwBit_1 <<
rwBit_0 << endl;
Wire.begin();
while (!Serial);
writeBatteryMode();
Serial << "-----------------------------" << endl;
readBatteryMode();
readBatteryVoltage();
