Question with 2 led's, different delay with millis when on/off
Hi can any one help ?
I'm having trouble figuring this out...
I'm trying to make 2 led's switch on but the first one I want to switch on right away, and the other one with a let's say 500ms delay.
and when i relese the button both of them I want to have a delay for like 2min or so but when they turn off i want one of them to turn off like 300ms fater then the other...
// These variables store the flash pattern
// and the current state of the LED
int buttonPin = 2;
int ledPin = 8;// the number of the LED pin
int ledState = LOW; // ledState used to set the LED
int led1Pin = 7;// the number of the LED pin
int led1State = LOW; // ledState used to set the LED
int buttonState = LOW;
unsigned long previousMillis = 0; // will store last time LED was updated
long OnTime = 0; // milliseconds of on-time
long OffTime = 2000; // milliseconds of off-time
// set the digital pin as output:
pinMode(ledPin, OUTPUT);
pinMode(led1Pin, OUTPUT);
pinMode(buttonPin, INPUT);
buttonState = digitalRead(buttonPin);
// check to see if it's time to change the state of the LED
if((buttonState == HIGH) && (currentMillis - previousMillis))
ledState = HIGH; // Turn it off
previousMillis = currentMillis >= OnTime; // Remember the time
digitalWrite(ledPin, ledState); // Update the actual LED
led1State = HIGH; // Turn it off
previousMillis = currentMillis; // Remember the time
digitalWrite(led1Pin, led1State); // Update the actual LED
else if ((buttonState == LOW) && (currentMillis - previousMillis >= OffTime))
led1State = LOW; // turn it on
previousMillis = currentMillis >= OffTime; // Remember the time
delay(300);
ledState = LOW; // turn it on
I have understood the contents of your post as follows:
1. You press K1 and hold ; as a result, LED13 will be ON instantly; LED12 will be ON after 500 ms.
2. You release K1; as a result LED13 will remain for ON for (2x60x1000 - 300 = ) ms from the moment you have released K1; LED12 will be OFF 300 ms later.
3. The Modified Version of your Program codes.
Expanded Form:
int buttonPin = 2;   //K1 is connected
int ledPin =  13;// LED138;// the number of the LED pin
//int ledState = LOW; // ledState used to set the LED
int led1Pin =  12;//LED127;// the number of the LED pin
//int led1State = LOW; // ledState used to set the LED
//int buttonState = LOW;
//unsigned long previousMillis = 0;        // will store last time LED was updated
//long OnTime = 0;           // milliseconds of on-time
//long OffTime = 2000;          // milliseconds of off-time
unsigned long currentMillis;
  pinMode(buttonPin, INPUT_PULLUP);
  digitalWrite(ledPin, LOW);
  digitalWrite(led1Pin, LOW);
  while(digitalRead(2) != LOW)
  digitalWrite(ledPin, HIGH);
  while(millis() - currentMillis != 500)
  digitalWrite(led1Pin, HIGH);
  while(digitalRead(2) != HIGH)
  while(millis() - currentMillis != 119700)
  digitalWrite(ledPin, LOW); // LEd13 OFF
  while(millis() - currentMillis != 300)
Compact Form:
  while (digitalRead(2) != LOW)
  callMillis(500);
  while (digitalRead(2) != HIGH)
  callMillis(119700);
  callMillis(300);
void callMillis(unsigned long x)
  while (millis() - currentMillis != x)
Ok thanks very much this works well :)) did not know how to add the delay in millis for that delay led for on/off ...
and another question can i simply integrate the fade function for a third led to fade when on stays on for those 2min and fades out ???
