Question
Scenario: If I send a digital signal, can i trigger a serial.write to another mcu
void loop(){
int state = digitalRead(button);
if (state == HIGH){
serial.write((byte)0xF5);
delay(10000);
Can it really happen?
Why not ?
Yes, but you have to spell "Serial" correctly, have the correct number of braces, declare "button" before it will compile.
"button" will be an input by default, but a pinMode wouldn't go amiss.
Code tags would be good too. I do believe you've been asked before to do that.
papyrus12:
Does it compile?
Does it run?
Does it do what you want?
Is this a hypothetical question?
Read this before posting a programming question
Point 6: "Make an informative subject description, not "help me, I'm a noob", nor something in all capitals. "
Your subject: Question
My response: Answer
You've done this before haven't you?
http://arduino.cc/forum/index.php/topic,125424
You post code that doesn't compile, not in code tags, and don't get the capitalization right.
You'll get a better response if you following the posting guidelines I linked to above.
Yeah, I already did this before several times, like two times already because I really wanna learn this arduino thing, because in our country the arduino is very thready topic for engineers yet thank you for your response.
papyrus12:
And yet you are still ignoring the feedback being given to you. You are not asking your questions in a way likely to get useful responses. All you're doing here is wasting people's time.
