question
I have one doubt in temperature sensor program in Arduino uno.
why are we using
/ Display Temperature in C
int tempReading = analogRead(tempPin);
float tempVolts = tempReading * 5.0 / 1024.0;
float tempC = (tempVolts - 0.5) * 100.0;
this in the program? what does the second line mean?
This one?
It is reading the analog pin that the temperature sensor is connected to.
If you meant this one:
it is converting the value, in the range 0 to 1023, to a value in the range 0 to 5.0, which is the range of voltages that can be read on an analog pin.
The value returned by analogRead() will be between 0 and 1023 for a range of voltages 0 to 5V. This line of code converts the 0 to 1023 value to a voltage. Note the use of decimal places in the constants to ensure that the calculation uses floats instead of integers.
PaulS:
Well, 0 to 4.995.
If it returns 0 to 1023, and you divide by 1024, you will never get a quotient of 1.
can we also take other value instead 1024?
You can, but them the math doesn't make sens.... ::slight_smile:
[/quote]
And in the third line why do we have to minus 0.5 with tempvolts?
The data sheet for your temperature sensor will explain that.
PaulS:
Okay, Thank you for your help. I will check data sheet in google.
I would not go all the way to Google and knock on there door to read a datasheet there... I would use Google to find it and read it in Adobe read in my shop... :smiley: ::slight_smile:
saikrishna:
I have a lengthy discussion about 1023 vs 1024 here.
My suggested formula is:
float voltage = ((float) rawADC  + 0.5 ) / 1024.0 * Vref;
(Vref being 5 in this particular case).
Thank you
I found this in the web:
DCs can vary greatly between microcontroller. The ADC on the Arduino is a 10-bit ADC meaning it has the ability to detect 1,024 (210) discrete analog levels. Some microcontrollers have 8-bit ADCs (28 = 256 discrete levels) and some have 16-bit ADCs (216 = 65,535 discrete levels).
So by reading all these informations which I have been known, I understood sensor value can also be divided with 1023 as like 1024. 1024 values mean 0 to 1023. so even if we divide 10235/1023 =1. and 10235/1024 =4.9951171. Is this right? Can you please let me know if I did any mistake.
For any practical purpose above about eight bits, you can use 2n-1 or 2n but 2n is correct.
1024 values mean 0 to 1023. so even if we divide 1023*5/1023 =1
Yes, but there are 1024 values (0 to 1023) so dividing by 1023 is skewing the results. And, the ADC doesn’t give you an exact value, each value represents a “slot” (a range). For example, a reading of 0 doesn’t mean 0 volts, it means somewhere between 0 and 5/1024 which is 0.00488 volts.
