Question
I wrote this code, but Arduino UNO reports this error and I do not know how to get it fixed. This code and who can check it. Thanks in advance
#include <DHT.h>
#define DHTPin 2                        //define DHT pin
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
DHT dht;
  dht.setup(DHTPin);
  lcd.begin(16,2);                      //initializes the LCD and specifies the dimensions
  float temp = dht.getTemperature();
  float humi = dht.getHumidity();
  lcd.setCursor(0,0);
  lcd.print("Temp: ");
  lcd.print(temp);
  lcd.print(" C");
  lcd.setCursor(0,1);
  lcd.print("Humi: ");
  lcd.print(humi);
  lcd.print(" %");
  delay(2000);
Error:
exit status 1
Error compiling for board Arduino/Genuino Uno.
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
I wrote this code, but Arduino reports this error and I do not know how to get it fixed. This code and who can check it. Thanks in advance
#include <DHT.h>
DHT dht;
 dht.setup(DHTPin);
 lcd.setCursor(0,0);
 lcd.print(temp);
 lcd.print(" C");
 lcd.setCursor(0,1);
 lcd.print(humi);
 lcd.print(" %");
 delay(2000);
Error
exit status 1
Moderator edit:
tags added.
Cross posted in Project Guidance.
Use code tags.
Threads merged.
exit status 1
What Arduino board are you using?
Please follow the advice given in reply #1
This error means, probably, that you haven't got one or more library that yoir code need. I don't know what library is, but you control to have installed everyone
I wrote this code, but Arduino UNO reports this error and I do not know how to get it fixed. This code and who can check it. Thanks in advance.
Code
#include <DHT.h>
DHT dht;
dht.setup(DHTPin);
lcd.setCursor(0,0);
lcd.print(temp);
lcd.print(" C");
lcd.setCursor(0,1);
lcd.print(humi);
lcd.print(" %");
delay(2000);
Error
Arduino: 1.8.5 (Windows Store 1.8.10.0) (Windows 10), Board: "Arduino/Genuino Uno"
C:\Users\Steva Markov\Documents\Arduino\sketch_aug01b\sketch_aug01b.ino:1:17: fatal error: DHT.h: No such file or directory
#include <DHT.h>
compilation terminated.
exit status 1
option enabled in File -> Preferences.
That means that the DHT library is not properly installed. How to install library.
When I compile it I get LOTs of errors. In general they mean that the "LiquidCrystel_I2C" and "DHT" libraries that I have installed are not the ones the sketch requires.
sketch_jul16a:5: error: 'POSITIVE' was not declared in this scope
sketch_jul16a:6: error: no matching function for call to 'DHT::DHT()'
 DHT dht;
/Users/john/Documents/Arduino/sketch_jul16a/sketch_jul16a.ino:6:5: note: candidates are:
In file included from /Users/john/Documents/Arduino/sketch_jul16a/sketch_jul16a.ino:2:0:
/Users/john/Documents/Arduino/libraries/DHT_sensor_library/DHT.h:40:4: note: DHT::DHT(uint8_t, uint8_t, uint8_t)
    DHT(uint8_t pin, uint8_t type, uint8_t count=6);
/Users/john/Documents/Arduino/libraries/DHT_sensor_library/DHT.h:40:4: note:   candidate expects 3 arguments, 0 provided
/Users/john/Documents/Arduino/libraries/DHT_sensor_library/DHT.h:38:7: note: constexpr DHT::DHT(const DHT&)
 class DHT {
/Users/john/Documents/Arduino/libraries/DHT_sensor_library/DHT.h:38:7: note:   candidate expects 1 argument, 0 provided
/Users/john/Documents/Arduino/libraries/DHT_sensor_library/DHT.h:38:7: note: constexpr DHT::DHT(DHT&&)
/Users/john/Documents/Arduino/sketch_jul16a/sketch_jul16a.ino: In function 'void setup()':
sketch_jul16a:9: error: 'class DHT' has no member named 'setup'
   dht.setup(DHTPin);
/Users/john/Documents/Arduino/sketch_jul16a/sketch_jul16a.ino: In function 'void loop()':
sketch_jul16a:14: error: 'class DHT' has no member named 'getTemperature'
sketch_jul16a:15: error: 'class DHT' has no member named 'getHumidity'
exit status 1
C:\Users\Steva Markov\AppData\Local\Temp\Rar$DIa0.347\DHT11_LCD\DHT11_LCD.ino: In function 'void loop()':
DHT11_LCD:30: error: expected primary-expression before '.' token
int h = dht.readHumidity();
DHT11_LCD:31: error: expected primary-expression before '.' token
int t = dht.readTemperature();
exit status 1
#include <dht.h> //DHT and LCD libraries
#define I2C_ADDR 0x27
#define BACKLIGHT_PIN 3
#define En_pin 2
#define Rw_pin 1
#define Rs_pin 0
#define D4_pin 4
#define D5_pin 5
#define D6_pin 6
#define D7_pin 7
LiquidCrystal_I2C lcd(0x27,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin);
dht DHT; //Declaring the DHT as a dht type to use it later
#define DHT11_PIN 7 //Declaring where the DHT signal pin is wired
void setup(){
              lcd.begin (16,2);
            lcd.setBacklightPin(BACKLIGHT_PIN,POSITIVE);
            lcd.setBacklight(HIGH);
            lcd.home ();
  //convert t to Fahrenheit
  int f = (t * 9.0)/ 5.0 + 32.0;
    // set cursor to (0,0):
  lcd.setCursor(0, 0);
    // ADDING TEXT
  lcd.print("P1nesap IoT");
  lcd.setCursor(0,1);
  lcd.print("Weather Monitor");
  delay(5000);
  lcd.clear();
  //END TEXT
     lcd.print(f);
     lcd.print("F  ");
     lcd.print(t);
     lcd.print("C");
  // set cursor to (16,1):
  lcd.setCursor(0,1);
  lcd.print("Humidity: ");
  lcd.print(h);
  lcd.print("%");
    delay(5000);
    //ADDING
    lcd.clear();
  lcd.setCursor(0,0);
  if ((f) >= 85 && (h) >= 51)  {
    lcd.print("Hot and humid...");
    lcd.setCursor(0,1);
    lcd.print("Drink water.");
  else if ((f) <= 85 && (f) >= 64 && (h) <= 51) {
    lcd.print("Perfect!");
    lcd.setCursor(0,1);
    lcd.print("Warm and dry.");
  else if ((f) <= 85 && (f) >= 64 && (h) >= 51) {
    lcd.print("Warm and moist,");
    lcd.setCursor(0,1);
    lcd.print("Sounds yummy.");
  else if ((f) >= 50 && (f) <= 64  && (h) >= 51) {
    lcd.print("Cool and damp...");
    lcd.setCursor(0,1);
    lcd.print("Raincoat?");
  else if ((f) >= 50 && (f) <= 64 && (h) <= 51) {
    lcd.print("Cool and dry.");
    lcd.setCursor(0,1);
    lcd.print("Wear a sweater.");
  else if ((f) >= 33 && (f) <= 50 && (h) <= 51) {
    lcd.print("Cool and dry,");
    lcd.setCursor(0,1);
    lcd.print("On the brisk side.");
  else if ((f) >= 33 && (f) <= 50 && (h) >= 51) {
    lcd.print("Raw weather...");
    lcd.setCursor(0,1);
    lcd.print("Read a book.");
  else if ((f) >= 17 && (f) <= 33 && (h) <= 51) {
    lcd.print("Ah, winter cold");
    lcd.setCursor(0,1);
    lcd.print("Dress in layers.");
  else if ((f) < 17 ) {
    lcd.print("OK, now it's");
    lcd.setCursor(0,1);
    lcd.print("REALLY cold!");
  else {
    lcd.print("Alert: alien");
    lcd.setCursor(0,1);
    lcd.print("atmosphere!");
  delay(5000);
  lcd.clear();
post all the code?
remember to use code tags
@PetarSRB, do not cross-post again.
exit status 1
#define En_pin 2
#define Rw_pin 1
#define Rs_pin 0
#define D4_pin 4
#define D5_pin 5
#define D6_pin 6
#define D7_pin 7
void setup(){
              lcd.begin (16,2);
            lcd.home ();
    // ADDING TEXT
  lcd.setCursor(0,1);
  delay(5000);
  lcd.clear();
  //END TEXT
     lcd.print(f);
     lcd.print("F  ");
     lcd.print(t);
     lcd.print("C");
  lcd.setCursor(0,1);
  lcd.print(h);
  lcd.print("%");
    delay(5000);
    //ADDING
    lcd.clear();
  lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.setCursor(0,1);
    lcd.setCursor(0,1);
    lcd.setCursor(0,1);
    lcd.setCursor(0,1);
    lcd.setCursor(0,1);
    lcd.setCursor(0,1);
    lcd.setCursor(0,1);
    lcd.setCursor(0,1);
  else {
    lcd.setCursor(0,1);
  delay(5000);
  lcd.clear();
Case matters. Try
  int h = DHT.readHumidity();
DON'T CROSS POST!!!!!!!!!!!!!!!!!!!!
http://forum.arduino.cc/index.php?topic=561092
I HAVE REPORTED THIS THREAD TO THE MODERATORS
This is your fifth thread you've started on this. You've already been told multiple times not to cross post. People have been trying to help you. Why would you do this?
Sorry Pert this is my first time on any forum, thanks for help.
Even if you have never been on a forum before you should know that when people tell you not to do something you shouldn't do it. Especially so when these are the people you're hoping to get free help from.
Ignorance of the rules is no excuse. There is a "How to use this forum - please read." post at the top of every forum section. Clearly you didn't read it. Please do so now:
http://forum.arduino.cc/index.php?topic=148850
When I use this int h = DHT.readHumidity(); (I will read now "How to use this forum")
Error is
DHT11_LCD:30: error: 'class dht' has no member named 'readHumidity'
DHT11_LCD:31: error: 'class dht' has no member named 'readTemperature'
  int t = DHT.readTemperature();
exit status 1
