Hallo everyone,
I am pretty new to arduino- I hope I post this in the correct section.
After some testing I managed to use 2x 74HC595N ( QJ88D4 25 UnG1403D dont know if these numbers are important.), these got 8 pins each side. Then I wanted to build one of these 8x8x8 LED Cubes in these projekts they use simular/same. The ones I ordered had now 10 pins each side ( 35C593KE4 SN74HC574N) .
I didnt find any example wiring for these so here are my questions:
- How much are these different from how these are working
- Can I use the same Code which I used for the ones with 8 pins- how to wire it then?
- How much LEDs could I controll with 10 of these
The code I used for the 8pin model ( from the internet)
int SER_Pin = 8; //pin 14 on the 75HC595
int RCLK_Pin = 9; //pin 12 on the 75HC595
int SRCLK_Pin = 10; //pin 11 on the 75HC595
//How many of the shift registers - change this
#define number_of_74hc595s 2
//do not touch
#define numOfRegisterPins number_of_74hc595s * 8
boolean registers[numOfRegisterPins];
void setup(){
pinMode(SER_Pin, OUTPUT);
pinMode(RCLK_Pin, OUTPUT);
pinMode(SRCLK_Pin, OUTPUT);
//reset all register pins
clearRegisters();
writeRegisters();
//set all register pins to LOW
void clearRegisters(){
for(int i = numOfRegisterPins - 1; i >= 0; i--){
registers[i] = LOW;
//Set and display registers
//Only call AFTER all values are set how you would like (slow otherwise)
void writeRegisters(){
digitalWrite(RCLK_Pin, LOW);
digitalWrite(SRCLK_Pin, LOW);
int val = registers[i];
digitalWrite(SER_Pin, val);
digitalWrite(SRCLK_Pin, HIGH);
digitalWrite(RCLK_Pin, HIGH);
//set an individual pin HIGH or LOW
void setRegisterPin(int index, int value){
registers[index] = value;
void loop(){
for(int i=0;i<numOfRegisterPins;i++){
setRegisterPin(i, HIGH);
writeRegisters();
delay(100);
setRegisterPin(i, LOW);
writeRegisters();
delay(100);
writeRegisters(); //MUST BE CALLED TO DISPLAY CHANGES
//Only call once after the values are set how you need.
