Hi, guys.
I am currently trying to build a program that can read the output from a Honeywell Magnetometer.
I believe I wire up the chip correctly. However, I am getting 255 for all 6 x,y,z (technically 3) outputs.
Can someone explain to me why this happens? Do I need to send message to initialize the chip, instead of just reading from it?
Someone help please, thanks.
Sincerely
P.S. I don't know how to post codes, but if you guys want it, I can definitely try it.
Please read and follow the directions in the "How to use this forum" post.
Here is my unfinished code.
#include <Wire.h>
void Convertion(byte val)
int n;
byte Useless1;
byte Useless2;
byte Useless3;
byte X_MSB;
byte X_LSB;
byte Z_MSB;
byte Z_LSB;
byte Y_MSB;
byte Y_LSB;
int X, x1, x2;
int Y, y1, y2;
int Z, z1, z2;
Wire.begin();
Wire.beginTransmission(0x3d);
Wire.write(0);
Wire.endTransmission();
Wire.requestFrom(0x3d,9);
Useless1 = Wire.read();
Useless2 = Wire.read();
Useless3 = Wire.read();
X_MSB = Wire.read();
X_LSB = Wire.read();
Z_MSB = Wire.read();
Z_LSB = Wire.read();
Y_MSB = Wire.read();
Y_LSB = Wire.read();
byte gg = B111;
x1 = (int)X_MSB;
x2 = (int)X_LSB;
X = x1 * pow(2,8) + x2;
Serial.println(X);
Serial.println(X_MSB, DEC);
Serial.println(X_LSB);
Serial.println(Z_MSB);
Serial.println(Z_LSB);
Serial.println(Y_MSB);
Serial.println(Y_LSB);
Serial.print("XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX\n");
Google “arduino hmc5883l” for lots of example code.
