Hello,
I am implementing a design using Nick Gammon Super cap circuit (https://www.gammon.com.au/forum/?id=12821).
The only modifications i have made are:
1)Instead of a single .47F capacitor, I have 2 5.6V 1F capacitors in parallel
2)I am using a 1284P instead of the 328P
I am at the stage in the work where I am connecting the circuit to a desktop power supply set at 7.3 volts.
The first problem I observed is that the desktop power supply is only registering .01 amp as the current being used. Given that design has a 5.6V 500mW Zener i was expecting the current to go higher than just 10mA.
Second, I have put a little SPST switch to isolate the MCU from the power, and as soon as i turn it on, and the MCU starts consuming power the voltage starts to drop, and it never stops going down, as if there was no power input from the desktop and the power was just coming from the super caps.
When the MCU is running, I measured the voltage at the entry point of the circuit , I get 7.33V but when I measured the voltage at the Zener cathode, the voltage reads about 3.90V
I am suspecting that I might need a Zener diode with 1W, but would love to hear feedback. Does anybody have any suggestions?
Thanks
