Questions about while loops, variables etc.
I'm going to use an arduino as processor for my rfid car "keyless" system. Right now im stuck at the start/stop button. Im going to try to explain:
While one variable (or input) is high, and while the start button is high, i want another output high as long as the start button is. Second time the start button is pressed, another output is set low. Can someone please make me an example code for this?
byte lastState = HIGH;
  pinMode(2, INPUT); // outside Input from somewhere
  pinMode(3, INPUT_PULLUP); // Start/stop button
  pinMode(13, OUTPUT); // Indicator Led/Engine startup
  byte myButton = digitalRead(3); //read the button
  if(digitalRead(2) == HIGH &&  myButton == LOW) // Button is seen as pressed when brought to ground "GND"
    if(myButton != lastState) // if the button was pressed then released, proceed
      digitalWrite(13, !digitalRead(13)); // toggle LED on/off
      lastState = myButton; // update the lastState, stops the Led from constant toggling
  else lastState = myButton; // when the button is unpressed, update the lastState again
