Hello! This has zero to do with the Arduino but I come here because everyone is super friendly and technologically orientated.
I want to know if I have some concepts right so I'm going to state facts and if someone would correct me, that would be awesome. I am also going to type questions.
I was reading up on WLANs and 802.11 and radio frequencies and Wifi and Wimax and I am confused about the hierarchy of it all.
As I understand it, Wifi is a type of WLAN that follows 802.11 standards. Wimax follows 802.16 standards.
First and foremost, I could not for the life of me find ANY other types of WLANS than wimax and wifi. What other options exist?
Additionally, some radio theory:
lower frequency = higher penetrating power and longer range
Higher frequency = higher rate of data transfer.
Therefore, would I be correct in saying that the ultimate goal is lowest frequency with highest data transfer rate? How theoretically would you achieve this? I.e. 802.11g is a standard defined for the 2.4GHz band that standardized speed from 11MBits/s to 54MBits/s (from the old 802.11a standard). I assume some sort of technological invention allowed this. How did it become possible to drastically increase data transfer rate and a lower frequency is what I am asking.
Additionally, what do these standards actually say? Do they only define the frequency and data transfer rate interval (i.e.24Mbps-54Mbps) a type of connection must have in order to classify as it? So put another way: if I can invent some way of transferring 54Mbps on a 2.4GHz band, I get the 'privilege' of saying I follow 802.11g standards?
What are 'channels?'
As I understand it, a channel is a subdivision of a 'band.' So for the 2.4GHz 'band,' channel 1 is 2401MHz to 2422MHz. Then channel 2 is 2406MHz to 2428MHz. Devices can communicate bits through each 'MHz' Frequency. So they can transfer 22 bits for a given time interval. One of the products I was looking at (you will see further down) has 'adjustable channel size support.' Why would you ever want to make a channel bigger or smaller?
Also why can't channels be KHz wide? Modern technology still doesn't have a fine enough resolution? Furthermore, why were channels selected to be specifically 22MHz wide? What advantage does this offer?
Next... the decibel...I hear all these things about decibel powers. The only thing I derived from wikipedia is that the decibel in radio communication is referenced to 1 milliwatt of power. But what does a 'decibel' actually do? Does it effect range? I thought that was frequency. Does it affect data transmittion?
[edit]: I know that decibel is a relative conversion using the log scale of power ratios. What I am saying is, what does having a higher decibel do.
So the reason I'm asking all this is because I am looking to somehow transfer high resolution images from a minimum distance of 3km and maximum of 50km. I need to know the best, most efficient method (with the context that one of the points will be moving at very high velocities).
Last time, the project team used this:
Product: Ubiquiti - Downloads
Datasheet: http://dl.ubnt.com/WSM5_DS.pdf
In the datasheet you will notice this:
For receiving, the WispStation M5 has -97 dB sensitivity at 1-24 Mbps with a tolerance of +/-2dB.
Now: what does that actually mean...?
Similarily, on the transmit side, It was 1-24Mbps with an Avg. Tx of 23dB. I found it curious that the 'sensitivity' was replaced with Avg. Tx. Again, what does this mean...?
I guess just some context: I am on a University aerospace team and we are building a UAV. I am a first year and there are some masters students working on it and even phd candidates helping out so I really want to know what I am talking about. Last time during a meeting they really grilled one of the students for their decisions in a gimbal the student designed and it was pretty nasty.
I really really appreciate the help! If some tech-savvy person would explain it in simple language, it would really help me to understand the complex picture. I also really value recommendations if anyone has any for best methods of doing the above (maximizing data transfer for 3km-50km).
