Questions for powering arduino and other devices connected to arduino
hell guys, i just want to ask how much volts and amps need to power up arduino? and devices connected to arduino like relay, coin hopper and lcd?
You posted this in a section of the forum where it clearly warns you not to post anything.
I will move your post.
Please read the forum guide in the sticky post at the top of most forum sections, before you break other rules.
5V and <50mA.
That's assuming you are using an Uno R3 or similar. There are many types/models of Arduino and they have different requirements.
As for your other components, the current and voltage they will require is the same as the length of a piece of string.
@zwack20
Your other topic on the same subject deleted.
Please do not duplicate your questions as doing so wastes the time and effort of the volunteers trying to help you as they are then answering the same thing in different places.
Please create one topic only for your question and choose the forum category carefully. If you have multiple questions about the same project then please ask your questions in the one topic as the answers to one question provide useful context for the others, and also you won’t have to keep explaining your project repeatedly.
Repeated duplicate posting could result in a temporary or permanent ban from the forum.
Could you take a few moments to Learn How To Use The Forum
Thank you.
You are putting the cart before the horse here and asking a question that really can't be answered. Every board and every sensor will have its own voltage and current ratings. Ideally you want to select components that all work at the same voltage and then add an appropriate external power supply if the sum of all sensors requires more current than the controller can source.
