Questions on Jpeg image processing on Arduino Due
Hi There,
I am very new to Arduino world and I would like to get some helps from you guys about the jpeg image processing. XD
All I need is to take a 640x480 8bit grey photo in jpeg ( output from the camera ) and convert it into an array (i.e 0 = white and 255 = black and each number represent a pixel of the photo ) and send it out one row after another one.
I know that the Arduino Due has 96KB of SRAM and I am guessing this is enough to do the work ?
Also, is there any resources (code / ideas , etc...) about converting jpeg into array with arduino ?
I did some search on the previous post about image processing and it seems to me that the biggest issue was the hardware limit ( not enough ram) , but I believe it has been solved now ( 640 pixel x 8bit/pixel x 1byte/8bit =~ 0.6KB each row)
Thank you so much , any comment helps :slight_smile:
Place to start is with file format , here is the link
http://www.fileformat.info/format/jpeg/egff.htm
How are you going to get the image?
I am looking at Due for same reason - more memory.
I tried to add external SRAM on Uno, but it just would not work reliably at any SPI speed.
Cheers Vaclav
There's the tricky bit.
JPEG works on 8 x 8 pixel blocks, so to send a row at a time, you'd have to buffer eight whole rows.
Huffman tables are going to consume a fair amount of RAM unless you can guarantee that they'll be the same from image to image.
I doubt its trivial to get (parts of?) libjpeg working on the device, but Atmel have a library for it, various
folks seem to be doing it: http://compgroups.net/comp.arch.embedded/libjpeg-+-cortex-m3/1299783
